MHB Problem Solving 2 - linear Equation
The problem involves a messenger riding between the front and rear of a marching army, traveling at 10 mi/hr while the soldiers move at 5 mi/hr. The total time for the messenger's round trip is 10 minutes, which is crucial for calculating the distance. To solve, one must consider the relative speed of the messenger compared to the soldiers and set up an equation based on the time taken for each leg of the journey. The goal is to determine the length of the column of soldiers. Understanding the setup and relative speeds is essential for finding the solution.
paulmdrdo1
here's the other problem.
1. An army of soldiers is marching down a road at 5 mi/hr. A messenger on horseback rides from the front to the rear and returns immediately, the total time taken being 10 minutes. Assuming that the messenger rides at the rate of 10mi/hr, determine the distance from the front to the rear.
I don't understand what's going in the problem. and what is it really requiring to solve. front of what and rear of what?
thanks!
Mathematics news on Phys.org
Front and rear of the column of soldiers. You have to find the length of the column.
how do I set-up the equation?
the messenger took two trips, front-rear and rear-front. Take the relative speed of the messenger and the column of soldiers then use it as the rate of each trip. :o
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
