MHB Problem-Solving Strategy for Dynamics Problems
A tailored problem-solving strategy for dynamics problems can significantly reduce frustration and improve efficiency. It emphasizes the importance of clearly stating the problem, writing relevant equations, and identifying inputs and expected outputs to demonstrate understanding. This structured approach mirrors practices used in professional engineering and scientific calculations, where citing sources and documenting steps is crucial. The discussion highlights that while the strategy is beneficial, not every aspect will apply to all problems. Adopting these practices can enhance clarity and accuracy in problem-solving.
Ackbach
MHB
I would highly recommend this to your attention. It can save you hours of frustration in solving problems. Note, however, that not every part necessarily applies to every problem.
View attachment Problem Solving Strategy.pdf
As per the discussion below, it is incumbent upon me to cite sources. This pdf was one I created from a combination of sources. The sole written source was Young and Freedman's University Physics. Other sources are verbal, from teachers, and my own experience.
For dynamics problems in particular, here is a tailored Problem-Solving Strategy.
View attachment Mechanics Problem-Solving Strategy.pdf
Enjoy!
Likes Juanda and homeworkhelpls
Mathematics news on Phys.org
When my colleagues and I solved a homework problem, we were required to state the problem as a demonstration that we understood the problem. Then we'd write the relevant equations, and inputs, and expected output. Again, the objective is to demonstrate that one understands the problem and the related physics and mathematics.
Then we'd write the solution, which could be the equation or set of equations, i.e., showing the work, so that the grader (grad student or professor) could understand how the problem was solved, or if there is an error, the grader could indicate the mistake.
Such a process is used much the same way in performing design or analysis calculations at work. If one uses a commercial program, usually one lists inputs and expected outputs. The inputs are listed with their source. Unless equations are very obvious (basic math), references (e.g., journal articles, handbooks, a standard or code (e.g., ASME code)) are cited with each equation.
Good engineering/scientific practices apply.
Likes galen_storm, chwala, Greg Bernhardt and 1 other person
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
