onezhizami87
- 1
Why temperature of refrigerator show higher than standard ? Which is the temperature standard should be below 5 degree of Celsius but it show 9 degrees
Some common signs of a temperature problem in a refrigerator include food spoiling quickly, inconsistent temperatures throughout the fridge, and ice melting faster than usual.
There are several potential causes for a refrigerator to have temperature problems, such as a faulty thermostat, dirty condenser coils, or a malfunctioning compressor. It could also be due to the door not sealing properly or being opened frequently.
First, check the temperature settings and make sure they are set correctly. Then, inspect the door seal and clean the condenser coils if necessary. If the problem persists, it may be best to call a professional for further diagnosis and repair.
In most cases, temperature problems with a refrigerator can be fixed. However, if the issue is due to a major component such as the compressor, it may be more cost-effective to replace the refrigerator.
To prevent temperature problems, make sure to clean the condenser coils regularly, keep the door closed as much as possible, and avoid overloading the fridge. It's also important to have regular maintenance and inspections by a professional to catch any issues before they become major problems.
