A Problem using Gutzwiller-RVB theory for high-temperature superconductivity
dieon
I'm currently working on reproducing a graph from the Gutzwiller-RVB theory of high-temperature superconductivity using Python. The graph plots χ_BBxy versus Δ, where Δ ranges from 16 to 26. I've implemented the theory's iterative parameter update scheme but encountered discrepancies in the plotted results compared to the expected graph.
Here's a simplified version of my Python code:
[CODE lang="python" title="code"]import numpy as np
import matplotlib.pyplot as plt
# Constants and parameters (initial guesses)
U = 20.0
t = 1.0
a = 1.0
N_1 = 20
N_2 = 20
N = N_1 * N_2
max_iterations = 500
tolerance = 1e-5
# Initial guesses for the parameters
m_s = 0.8
delta = 0.8
chi_AB_up = 0.8
chi_AB_down = 0.8
chi_BB_up = 0.8
chi_BB_down = 0.8
chi_BBxy_up = 0.8
chi_BBxy_down = 0.8
Delta_AB = 0.8
# Generate wave vectors
def generate_wave_vectors(a, N_1, N_2):
b1 = (2 * np.pi / a) * np.array([1, 0])
b2 = (2 * np.pi / a) * np.array([0, 1])
K = []
for n_1 in range(-N_1 // 2, N_1 // 2):
for n_2 in range(-N_2 // 2, N_2 // 2):
k = (n_1 / N_1) * b1 + (n_2 / N_2) * b2
K.append(k)
return np.array(K)
K = generate_wave_vectors(a, N_1, N_2)
def gamma_k(k):
return 2 * (np.cos(k[0]) + np.cos(k[1]))
def gamma_sc(k):
return np.cos(k[0]) - np.cos(k[1])
def gamma_k_prime(k):
return 2 * (np.cos(2*k[0]) + np.cos(2*k[1])) + 4 * (np.cos(k[0] + k[1]) + np.cos(k[0] - k[1]))
def h1_up(k, m_s, delta, chi_BB_up, chi_BBxy_up, t, Delta, U):
g1 = 1
gs = 4 / ((1 + delta)**2 - m_s**2)
h1_up_val = (U - Delta) / 2 * (1 + delta - m_s) / 2 \
- t**2 / Delta * (4 * (1 - 2 * delta) + g1 * (2 * chi_BB_up + 4 * chi_BBxy_up) + g1 * (1 - delta + m_s) / 2 * gamma_k_prime(k)) \
- 2 * t**2 * gs * m_s / (U + Delta) + 2 * t**2 / (U + Delta) * (1 - delta)
return h1_up_val
def h1_down(k, m_s, delta, chi_BB_down, chi_BBxy_down, t, Delta, U):
g1 = 1
h1_down_val = (U - Delta) / 2 * (1 + delta + m_s) / 2 \
- t**2 / Delta * (4 * (1 - 2 * delta) + g1 * (2 * chi_BB_down + 4 * chi_BBxy_down) + g1 * (1 - delta - m_s) / 2 * gamma_k_prime(k)) \
+ 2 * t**2 * gs * m_s / (U + Delta) + 2 * t**2 / (U + Delta) * (1 - delta)
return h1_down_val
def h2_up(k, delta, m_s, chi_AB_up, t, Delta, U):
g1 = 1
g2 = 4 * delta / ((1 + delta)**2 - m_s**2)
h2_up_val = -t * g1 - t**2 / Delta * (-2 * chi_AB_up + 6 * g2 * chi_AB_up) \
- t**2 / (U + Delta) * (gs * (0.5 * chi_AB_up + chi_AB_up) + 0.5 * chi_AB_up)
return h2_up_val * gamma_k(k)
def h2_down(k, delta, m_s, chi_AB_down, t, Delta, U):
g1 = 1
h2_down_val = -t * g1 - t**2 / Delta * (-2 * chi_AB_down + 6 * g2 * chi_AB_down) \
- t**2 / (U + Delta) * (gs * (0.5 * chi_AB_down + chi_AB_down) + 0.5 * chi_AB_down)
return h2_down_val * gamma_k(k)
def h3(k, delta, m_s, Delta_AB, t, Delta, U):
gt_up = 2 * delta / (1 + delta + m_s)
gt_down = 2 * delta / (1 + delta - m_s)
h3_val = 4 * t**2 / Delta * (1 - g2) + 4 * t**2 / (U + Delta) * (3 * gs / 4 - 1 / 4) - 2 * t**2 / Delta * (gt_up + gt_down)
return h3_val * Delta_AB / 2 * gamma_sc(k)
def omega_up(k, m_s, delta, chi_BB_up, chi_BBxy_up, chi_AB_up, t, Delta, U):
alpha_up, beta_up, _, _ = alpha_beta(k, m_s, delta, chi_BB_up, chi_BBxy_up, chi_AB_up, t, Delta, U)
h1_up_k = h1_up(k, m_s, delta, chi_BB_up, chi_BBxy_up, t, Delta, U)
h2_up_k = h2_up(k, delta, m_s, chi_AB_up, t, Delta, U)
return h1_up_k * (alpha_up**2 - beta_up**2) - 2 * h2_up_k * alpha_up * beta_up
def omega_down(k, m_s, delta, chi_BB_down, chi_BBxy_down, chi_AB_down, t, Delta, U):
_, _, alpha_down, beta_down = alpha_beta(k, m_s, delta, chi_BB_down, chi_BBxy_down, chi_AB_down, t, Delta, U)
h1_down_k = h1_down(k, m_s, delta, chi_BB_down, chi_BBxy_down, t, Delta, U)
h2_down_k = h2_down(k, delta, m_s, chi_AB_down, t, Delta, U)
return h1_down_k * (alpha_down**2 - beta_down**2) - 2 * h2_down_k * alpha_down * beta_down
def nu(k, delta, m_s, Delta_AB, t, Delta, U):
alpha_up, beta_up, alpha_down, beta_down = alpha_beta(k, m_s, delta, chi_BB_up, chi_BBxy_up, chi_AB_up, t, Delta, U)
return -h3(k, delta, m_s, Delta_AB, t, Delta, U) * (alpha_up * beta_down + alpha_down * beta_up)
def alpha_beta(k, m_s, delta, chi_BB_up, chi_BBxy_up, chi_AB_up, t, Delta, U):
E_up_k_val = E_up_k(k, m_s, delta, chi_BB_up, chi_BBxy_up, chi_AB_up, t, Delta, U)
E_down_k_val = E_down_k(k, m_s, delta, chi_BB_down, chi_BBxy_down, chi_AB_down, t, Delta, U)
alpha_up = np.sqrt(0.5 * (1 - h1_up_k / E_up_k_val))
beta_up = np.sqrt(0.5 * (1 + h1_up_k / E_up_k_val))
alpha_down = np.sqrt(0.5 * (1 - h1_down_k / E_down_k_val))
beta_down = np.sqrt(0.5 * (1 + h1_down_k / E_down_k_val))
return alpha_up, beta_up, alpha_down, beta_down
def E_up_k(k, m_s, delta, chi_BB_up, chi_BBxy_up, chi_AB_up, t, Delta, U):
return np.sqrt(h1_up_k**2 + h2_up_k**2)
def E_down_k(k, m_s, delta, chi_BB_down, chi_BBxy_down, chi_AB_down, t, Delta, U):
return np.sqrt(h1_down_k**2 + h2_down_k**2)
def u_v_squared(k, m_s, delta, chi_AB_up, chi_AB_down, chi_BB_up, chi_BBxy_up, chi_BB_down, chi_BBxy_down, t, Delta, U):
omega_up_val = omega_up(k, m_s, delta, chi_BB_up, chi_BBxy_up, chi_AB_up, t, Delta, U)
omega_down_val = omega_down(k, m_s, delta, chi_BB_down, chi_BBxy_down, chi_AB_down, t, Delta, U)
nu_k = nu(k, delta, m_s, Delta_AB, t, Delta, U)
denominator = np.sqrt((omega_up_val + omega_down_val)**2 + 4 * nu_k**2)
u1_squared = 0.5 * (1 + (omega_up_val + omega_down_val) / denominator)
u2_squared = 0.5 * (1 - (omega_up_val + omega_down_val) / denominator)
v1_squared = u2_squared
v2_squared = u1_squared
return u1_squared, u2_squared, v1_squared, v2_squared
# Function to update parameters
def update_parameters(k_points, m_s, delta, chi_AB_up, chi_AB_down, chi_BB_up, chi_BB_down, chi_BBxy_up, chi_BBxy_down, Delta_AB, t, Delta):
sum_m_s = 0
sum_delta = 0
sum_chi_AB_up = 0
sum_chi_AB_down = 0
sum_chi_BB_up = 0
sum_chi_BB_down = 0
sum_chi_BBxy_up = 0
sum_chi_BBxy_down = 0
sum_Delta_AB = 0
for k in k_points:
N_1 = 20
N_2 = 20
N = N_1 * N_2
u1_squared, u2_squared, v1_squared, v2_squared = u_v_squared(k, m_s, delta, chi_AB_up, chi_AB_down, chi_BB_up, chi_BBxy_up, chi_BB_down, chi_BBxy_down, t, Delta, U)
u1 = np.sqrt(u1_squared)
u2 = np.sqrt(u2_squared)
v1 = np.sqrt(v1_squared)
v2 = np.sqrt(v2_squared)
# Update m_s and delta
sum_m_s += ((alpha_up**2 - alpha_down**2) * v1_squared + (beta_up**2 - beta_down**2) * v2_squared)/N
sum_delta += (0.5 * (alpha_up**2 * (v1_squared - v2_squared) + beta_up**2 * (v1_squared - v2_squared) + alpha_down**2 * (v1_squared - v2_squared) + beta_down**2 * (v1_squared - v2_squared)))/N
# Update chi_AB_up, chi_AB_down, chi_BB_up, chi_BB_down, chi_BBxy_up, chi_BBxy_down
sum_chi_AB_up += 0.25 * alpha_up * beta_up * (v2_squared - v1_squared)/N
sum_chi_AB_down += 0.25 * alpha_down * beta_down * (v2_squared - v1_squared)/N
sum_chi_BB_up += (np.cos(2*k[0]) + np.cos(2*k[1])) * (alpha_up**2 * v2_squared + beta_up**2 * v1_squared)/N
sum_chi_BB_down += (np.cos(2*k[0]) + np.cos(2*k[1])) * (alpha_down**2 * v2_squared + beta_down**2 * v1_squared)/N
sum_chi_BBxy_up += 2 * np.cos(k[0]) * np.cos(k[1]) * (alpha_up**2 * v2_squared + beta_up**2 * v1_squared)/N
sum_chi_BBxy_down += 2 * np.cos(k[0]) * np.cos(k[1]) * (alpha_down**2 * v2_squared + beta_down**2 * v1_squared)/N
sum_Delta_AB += (alpha_down * beta_up * u2 * v2 - alpha_up * beta_down * u1 * v1) * gamma_sc(k)
new_m_s = sum_m_s
new_delta = sum_delta
new_chi_AB_up = sum_chi_AB_up
new_chi_AB_down = sum_chi_AB_down
new_chi_BB_up = sum_chi_BB_up
new_chi_BB_down = sum_chi_BB_down
new_chi_BBxy_up = sum_chi_BBxy_up
new_chi_BBxy_down = sum_chi_BBxy_down
new_Delta_AB = sum_Delta_AB
return new_m_s, new_delta, new_chi_AB_up, new_chi_AB_down, new_chi_BB_up, new_chi_BB_down, new_chi_BBxy_up, new_chi_BBxy_down, new_Delta_AB
# Initializing the plot data lists
Delta_values = np.linspace(16, 26, 50)
chi_BBxy_up_values = []
chi_BBxy_down_values = []
# Loop over Delta values
for Delta in Delta_values:
m_s, delta, chi_AB_up, chi_AB_down, chi_BB_up, chi_BB_down, chi_BBxy_up, chi_BBxy_down, Delta_AB = 0.8, 0.8, 0.8, 0.8, 0.8, 0.8, 0.8, 0.8, 0.8
for iteration in range(max_iterations):
new_m_s, new_delta, new_chi_AB_up, new_chi_AB_down, new_chi_BB_up, new_chi_BB_down, new_chi_BBxy_up, new_chi_BBxy_down, new_Delta_AB = update_parameters(
K, m_s, delta, chi_AB_up, chi_AB_down, chi_BB_up, chi_BB_down, chi_BBxy_up, chi_BBxy_down, Delta_AB, t, Delta
if np.abs(new_Delta_AB - Delta_AB) < tolerance:
break
m_s, delta, chi_AB_up, chi_AB_down, chi_BB_up, chi_BB_down, chi_BBxy_up, chi_BBxy_down, Delta_AB = new_m_s, new_delta, new_chi_AB_up, new_chi_AB_down, new_chi_BB_up, new_chi_BB_down, new_chi_BBxy_up, new_chi_BBxy_down, new_Delta_AB
chi_BBxy_up_values.append(chi_BBxy_up)
chi_BBxy_down_values.append(chi_BBxy_down)
# Plotting the results
plt.plot(Delta_values, chi_BBxy_down_values, label='χ_BBxy_down', marker='o')
plt.plot(Delta_values, chi_BBxy_up_values, label='χ_BBxy_up', marker='+')
plt.xlabel('Δ')
plt.ylabel('χ_BBxy')
plt.title('Plot of χ_BBxy vs Δ')
plt.grid(True)
plt.show()[/CODE]
Key Issues:
  1. Graph Accuracy: The plotted graph of χ_BBxy against Δ does not closely match the expected results from the literature. Even small changes in initial parameters or the size of the wave vector grid (N_1 and N_2) significantly alter the output.
  2. Parameter Sensitivity: I observe that varying initial guesses (m_s, delta, etc.) and the grid size (N_1, N_2) affect the final plotted values of χ_BBxy. Is this expected behavior, or could there be an error in how I'm updating parameters or generating wave vectors?
Request for Assistance:
  • Clarification: Is it typical for small changes in initial parameters or the grid size to affect the output significantly in numerical simulations of the Gutzwiller-RVB theory?
  • Code Review: Could you please review the provided Python code snippet to identify potential errors or improvements that might lead to more accurate results?
(I've also attached a file with the formulas I've used)
Any guidance or suggestions would be greatly appreciated!
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
