Problem using Newtons second law
In summary, when a sky-diver of mass m has their chute open, they are acted upon by a downward force Fg due to gravity and an upward force Fr due to air resistance. Using Newton's Second Law of Motion, the acceleration a can be written as a function of velocity v, with the equation a = g - (kv/m) where k is a constant of proportionality. The negative sign is included to account for the opposing force of air resistance.
Chosen-wun
Once her chute opens, a sky-diver of mass m is acted upon by a downward force Fg due to gravity, and an upward force Fr due to air resistance. If Fg = mg, where g is gravitational acceleration, and Fr is proportional to velocity v, use Newton’s Second Law of Motion to write acceleration a as a function of velocity v.
I don't know if I'm on the right track
Fnet = ma
fnet = Fg+ Fr
Fg = mg
Mg + Fr = ma
yes on right track except the signs. Now since [itex]F_r[/itex] is proportional to velocity v, we can write
[tex]F_r=kv[/tex] where k is constant of proportionality.
[tex]\Rightarrow mg-kv=ma[/tex]
the negative sign is there since the air drag opposes the downward motion,
[tex]\therefore a = g-\frac{kv}{m}[/tex]
That makes a lot more sense, thank you.
Related to Problem using Newtons second law
1. What is Newton's second law?
Newton's second law states that the force applied to an object is equal to the mass of the object multiplied by its acceleration.
2. How do you use Newton's second law to solve problems?
To use Newton's second law, you must first identify the mass and acceleration of the object in question. Then, you can use the formula F=ma to calculate the force acting on the object.
3. Can Newton's second law be applied to all types of motion?
Yes, Newton's second law can be applied to all types of motion, including linear motion, circular motion, and rotational motion.
4. What are some common examples of problems that can be solved using Newton's second law?
Some examples include calculating the force required to move an object at a certain acceleration, determining the acceleration of an object given a certain force, and analyzing the motion of objects on an inclined plane.
5. Are there any limitations to Newton's second law?
Newton's second law is based on the assumption of constant mass and does not account for factors such as air resistance or friction. It also does not apply to objects moving at speeds close to the speed of light.
