Problem when std::function refers to member function
  • Thread starter Thread starter ORF
    Function Member
The discussion centers on the implementation of member functions within a class hierarchy in C++. A user seeks to enable a member function from one class (dev_b) to call a member function from another class (dev_a) within a composite class (master_t). The initial attempt to pass the member function directly resulted in a compilation error due to the lack of an object reference. The solution involves using a lambda function or std::bind to correctly reference the member function of dev_a. The suggested approach simplifies the code by allowing ShowB to be implemented in a manner similar to ShowA, thereby avoiding complex syntax. The conversation also emphasizes the importance of including necessary headers for the code to compile successfully. Overall, the key takeaway is the need for proper object referencing when dealing with member functions across different classes in C++.
ORF
Hi,
I have a class master_t which is composed by two other classes, dev_a, dev_b. I would like that a member function from the dev_b object (within master_t) could use a member function of dev_a object (within master_t). This is a minimal working code, where line 26 implements this feature.
[CODE lang="cpp" title="Minimal working example" highlight="26"]class dev_a
public:
int a = {1};
void ShowA( ){ std::cout << "dev_a::a = " << a << '\n'; return; }
class dev_b
public:
int b = {2};
void ShowB( std::function<void(void)> ShowA ){ std::cout << "dev_b::b = " << b << '\n'; ShowA(); return; }
class master_t
public:
dev_a one;
dev_b two;
// Driver code
int main()
master_t obj;
obj.two.ShowB( [&](){ obj.one.ShowA(); return;} );
return 0;
}[/CODE]
I naively tried first with obj.two.ShowB( obj.one.ShowA ); but I got the following error
[CODE lang="cpp" title="Error message"]error: no matching function for call to ‘dev_b::ShowB(<unresolved overloaded function type>)’
obj.two.ShowB( obj.one.ShowA );[/CODE]
I have two questions:
a) The cause of the error is because when passing the function like obj.two.ShowB( obj.one.ShowA ); is missing the reference to the actual object obj.one?
b) Would it be better to implement the function dev_b::ShowB as member function of master_t instead, so it can have access to both dev_a and dev_b objects?
Thank you for your time. Any comment is welcome.
Cheers,
ORF
Technology news on Phys.org
Your code worked fine for me, and produced this output:
Code:
dev_b::b = 2
dev_a::a = 1
Maybe I am missing the point of your question ... ?
It seems simpler to me to implement ShowB() similar to how ShowA() is implemented. That would eliminate the need for the convoluted code of line 26 - obj.two.ShowB( [&](){ obj.one.ShowA(); return;} );. This line truly deserves some commenting.
To make your code compile and run, I added the following lines at the top.
C++:
#include <iostream>
#include <functional>
using std::cout;
using std::function;
That is correct. You can use a lambda to capture and call the object, or you can use std::bind, for example like
[CODE title="C++"]obj.two.ShowB( std::bind(&dev_a::ShowA, &obj.one) );[/CODE]
Likes ORF and jim mcnamara
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
