Problem with a Differential in a Non Inertial System.
In summary: I think I understand what you are saying now. Basically, when the ball starts out closer to the equilibrium point (x = Mg/(mw^2)), the solution is given by an exponential function with a negative slope. However, as the ball gets further away from the equilibrium point, the solution becomes an exponential function with a positive slope.
paalfis
69
A ball of mass 'm' is inside of a tube that rotates in a horizontal plane around the vertical axis (Drawing a circunference). Attached to the ball (inside of the tube) there is a massless, inextensible rope that goes to the midpoint of the circle described by the rotating tube. The other end of the rope is attached to a hanging block of mass 'M'. Describe the motion of the ball in terms of its position as a function of time.
2. Homework Equations
My non inercial reference system was x parallel to the tube, z perpendicular to the plane (in the opposite direction of the hanging block) and y in the plane but perpendicular to x.
After solving the dynamics of the problem, the differential I got (I think it is correct) was:
m * w2 * x - M*g = (m+M) * x''
where w is the angular speed of the tube and x is the position of the ball along the tube starting from the center of the circumference described by it. x'' is the acceleration of the ball along the tube, which is the same of the acceleration of the hanging block. Of course, the first term is the centrifugal force and the second one is the weight of the block.
Now my problem is the next one. When solving this differential (proposing for the homogeneous solution: A * eL*t , and for the particular solution x''=0) I only got a solution where x increases exponential with time, but what about the other case, in which the hanging block is heavier and x decreases with time?
Thanks!
Actually, after putting in the initial conditions (x'(t=0)=0 and x(t=0)=R/2 , where R is the length of the tube) the solution (wich was something like A1*eL*t+A2*E-L*t+particular solution ) has A1=A2= 1/2 * [ (R/2 - [ (M*g)/(m*w2) ] ] which makes sense, it is negative for heavier blocks. Is this correct?
The equilibrium (x = Mg/(mw^2)) is unstable and regardless of how you deviate from it. Thus, you should expect to get exponentially increasing solutions on both sides. In one case x will grow exponentially and in the other it will decrease exponentially away from the equilibrium point. The only thing is that in the decreasing solution, there is an obvious change of dynamics when the ball reaches x = 0.
Right, right.. Can you please clarify a little bit more about the exponentially decreasing part? do you mean something like -eL*t or something like -e-L*t ?
I would guess you mean -eL*t , right?
paalfis said:
do you mean something like -exp(L*t)
This was what I intended, e.g., when the ball starts out at a radius shorter than the equilibrium point at zero velocity. As you have already discovered, the solutions are given in terms of exponential functions also with exp(-Lt). A more convenient parametrization of these are cosh(Lt) and sinh(Lt).
Thanks!
FAQ: Problem with a Differential in a Non Inertial System.
1. What is a differential in a non-inertial system?
A differential in a non-inertial system refers to a small change in position or velocity of an object in a system that is accelerating or rotating. This can also be thought of as the difference between two infinitesimally close points in the system.
2. Why is there a problem with differentials in non-inertial systems?
In non-inertial systems, the laws of physics are not the same as in inertial systems, which means that the equations used to calculate differentials may not be accurate. This can lead to incorrect results and a lack of consistency in the system.
3. How does the problem with differentials affect scientific experiments?
The problem with differentials in non-inertial systems can make it difficult to accurately measure and predict the behavior of objects in these systems. This can affect the results of scientific experiments and make it challenging to draw conclusions or make accurate predictions.
4. Are there any solutions to the problem with differentials in non-inertial systems?
Yes, there are several techniques and mathematical tools that can be used to account for the discrepancies in non-inertial systems. These include using fictitious forces, transforming equations to an inertial frame, and using general relativity principles.
5. How important is it to consider the problem with differentials in non-inertial systems?
It is crucial to consider the problem with differentials in non-inertial systems, especially in fields such as physics and engineering where precise measurements and calculations are essential. Ignoring this problem can lead to incorrect results and a misunderstanding of the behavior of objects in these systems.
