Problem with a product of 2 remainders (polynomials)
In summary, the Chinese remainder theorem states that if a and b are two integers, then V(x) must have the form ##ax+b##.
another_dude
[/B]
Polynomial P(x) when divided by (x-2) gives a remainder of 10. Same polynomial when divided by (x+3) gives a remainder of 5. Find the remainder the polynomial gives when divided by (x-2)(x+3).
2. Homework Equations
Polynomial division, remainder theorem
From the problem and the remainder theorem I got 2 equations:
1) P(2)=10 and 2) P(-3)=5
More generally, we get this: P(x)=(x-2)D(x)+10=(x+3)F(x)+5 , where D(x), F(x) some polynomials one rank lower than P(x).
Tried multiplicating, dividing and adding the equations in different ways but couldn't get a useful relation, namely P(x)=(x-2)(x+3)G(x)+ V(x), where V(x) is the wanted remainder. Any thoughts?
another_dude said:
[/B]
Do you know the Chinese remainder theorem?
Never heard of it before.
##V(x)## must have the form ##ax+b##, right? What are ##V(2)## and ##V(-3)##?
Likes SammyS and another_dude
Oh right, didn't think of that actually. Well, from the remainder theorem we get 1) V(2)=P(2)=10 2) V(-3)=P(-3)=5 . Then you solve the system for a and b. Thanks!
FAQ: Problem with a product of 2 remainders (polynomials)
1. What is a remainder in a polynomial?
A remainder in a polynomial is the result of dividing one polynomial by another. It is the part that is left over after the division has been completed.
2. How do you know if a polynomial has a problem with its remainders?
A polynomial may have a problem with its remainders if the remainder is not equal to zero when divided by the divisor. This indicates that there is an error in the calculation or that the polynomial is not divisible by the divisor.
3. What causes a problem with a product of 2 remainders in a polynomial?
A problem with a product of 2 remainders in a polynomial can be caused by a variety of factors, such as incorrect coefficients, missing terms, or errors in the division process.
4. How can a problem with a product of 2 remainders be solved?
The first step in solving a problem with a product of 2 remainders is to carefully check the calculations and make sure all coefficients and terms are correct. If the error cannot be identified, it may be necessary to use a different method of division or consult a mathematical expert for assistance.
5. Are there any common mistakes that can lead to a problem with a product of 2 remainders?
Yes, some common mistakes that can lead to a problem with a product of 2 remainders include using the wrong divisor, forgetting to include terms in the division process, and making errors in the multiplication of polynomials.
