Problem with basic doppler effect question
In summary, using the correct formula for the Doppler effect, the listener will hear a frequency of 10,000 Hz as the source of a 1 kilohertz sound moves closer at a speed of .9 times the speed of sound.
PsychonautQQ
784
The source of a 1 kilohertz sound is getting closer to the listener at a speed of .9 times the speed of sound. What frequency does the listener hear?
fl = ((v-vs) / (v + vl))fs
((343+343(.9)) / 343)*1000=1900 Hz
this is the wrong answer, what did I do wrong? it's supposed to be 10,000 Hz
Correct formula:
[itex]f = \frac{c\ +\ v_{r}}{c\ +\ v_{s}} \cdot f_{0}[/itex]
In your problem the source is getting closer, so [itex]v_{s}[/itex] is negative.
As you didn't miss that, your error is in the formula. Use the one above.
You also SUMMED values that you should have SUBTRACTED.
Remember:
[itex]v_{r}[/itex] is the velocity of the receiver relative to the medium; positive if the receiver is moving towards the source;
[itex]v_{s}[/itex] is the velocity of the source relative to the medium; positive if the source is moving away from the receiver;
Use this equation : ##f = f_0( \frac{v}{v ± v_s} )##
Where ##f## is the stationary frequency. ##f_2## is the apparent frequency detected. ##v## is the speed of sound in air and ##v_s## is the speed of the source.
Since the source is moving closer to your listener, you want to use ##v - v_s## ( Doppler effect ). Don't forget to convert kHz to Hz otherwise this won't work!
I got ##f = 10000 Hz##.
Related to Problem with basic doppler effect question
What is the basic doppler effect?
The doppler effect is the change in frequency or pitch of a wave as the source of the wave moves towards or away from an observer. This effect is commonly experienced with sound waves, such as when a siren on a moving ambulance changes in pitch as it passes by.
How does the basic doppler effect work?
The basic doppler effect is based on the principle that as the source of a wave moves towards an observer, the waves will be compressed and have a higher frequency. Conversely, as the source moves away from the observer, the waves will be stretched out and have a lower frequency. This change in frequency is what causes the perceived change in pitch.
What factors can affect the doppler effect?
The doppler effect can be affected by the speed and direction of the source, as well as the speed and direction of the observer. Additionally, the medium through which the wave is traveling, such as air or water, can also impact the doppler effect.
What are some real-world applications of the doppler effect?
The doppler effect is used in a variety of applications, including radar and sonar technology, which use the change in frequency of reflected waves to detect the speed and direction of moving objects. It is also used in medical imaging, such as ultrasounds, to measure blood flow and heart rate.
How is the doppler effect related to the redshift and blueshift of light from distant galaxies?
The doppler effect can also be observed with light waves, which can be shifted to a higher or lower frequency depending on the speed and direction of the source. In astronomy, the doppler effect is used to measure the relative motion of galaxies and stars, with a redshift indicating a source moving away and a blueshift indicating a source moving towards the observer.
