Problem with cross multiplication
In summary, the oxygen carrying capacity of hemoglobin is 1.34 mL of O2 per gram of hemoglobin, and a person with 30 mL of O2 per 100 mL of blood would have a Hb concentration of 22.4 g/100 mL.
Trinley
Hello, I have been poring over this problem for days, and I would really appreciate some help. I'm not sure if it's an algebra problem exactly. It's from my physiology class. The professor said it's simple cross multiplication, and I asked him to explain it again, but I didn't understand his explanation. Here's the problem:
The oxygen carrying capacity of hemoglobin is about 1.34 mL of O2 per gram of hemoglobin (Hb).
Imagine a person with 30 mL O2 per 100 mL of blood.
What would his Hb concentration be?
So I have these two figures:
1.34 mL O2 / 1 g Hb
and
30 mL O2/100 mL blood.
I know the answer is about 22.4 g Hb / 100 mL blood. I know 30/1.34 = 22.4, but I would like to really understand how the problem is set up so that it makes sense to me.
Can anyone help? Thank you.
Mathematics news on Phys.org
1.34 mL O2 / 1 g Hb
and
Set up ratios..
$\displaystyle \begin{align*} O_2 &: \textrm{ Hb } \\ 1.34 &: 1 \\ 1 &: \frac{1}{1.34} \\ 1 &: \frac{100}{134} \\ 1 &: \frac{50}{67} \\ \\ O_2 &: \textrm{ Blood } \\ 30 &: 100 \\ 1 &: \frac{100}{30} \\ 1 &: \frac{10}{3} \\ \\ \textrm{Hb } &: \textrm{ Blood } \\ \frac{50}{67} &: \frac{10}{3} \\ \frac{3}{10} \cdot \frac{50}{67} &: 1 \\ \frac{15}{67} &: 1 \end{align*}$
So the concentration is $\displaystyle \begin{align*} \frac{15}{67} \end{align*}$ mL of Hb to every mL of blood.
That does give the right answer. The professor showed this question in class and asked us calculate it without explaining how. Some people pulled out their phones and gave the answer about 20 seconds. I don't see how they were able to do that. It seems like this way of setting up ratios would take longer and would not be something you can plug into the calculator for a quick answer. Clearly they knew to divide 30 by 1.34, but I don't know how.
The professor showed me that I would just have to set up a simple cross multiplication, but he spoke very quickly and I couldn't follow. Is there a way to set this up as cross multiplication with a minimum of steps?
FAQ: Problem with cross multiplication
What is cross multiplication?
Cross multiplication is a mathematical method used to solve equations that involve fractions. It involves multiplying the numerator of one fraction by the denominator of the other fraction and vice versa.
When should I use cross multiplication?
Cross multiplication is typically used when solving equations that involve proportions or ratios. It can also be used to solve equations with fractions in order to find the value of a variable.
What are some common mistakes when using cross multiplication?
One common mistake when using cross multiplication is forgetting to switch the position of the numerator and denominator when multiplying. Another mistake is not reducing the fractions before solving the equation.
Can cross multiplication be used for all equations with fractions?
No, cross multiplication can only be used for equations that have two fractions set equal to each other. It cannot be used for equations with more than two fractions or equations with variables on both sides.
Are there other methods to solve equations with fractions?
Yes, there are other methods such as finding a common denominator, using the distributive property, or using the inverse operation. It is important to understand and use multiple methods to solve equations with fractions.
