Problem with distance in relation to acceleration.
In summary, the conversation discusses a problem involving a car at a red light on a horizontal road that accelerates to 14 m/s in 7 seconds, maintains a constant speed for 10 seconds, and then decelerates at -3.5 m/s^2. The conversation also includes a discussion about calculating the time spent decelerating, graphing the speed in relation to time, and finding the average speed during acceleration and deceleration. The group also talks about calculating the total distance traveled by the car and how to do so using equations of motion.
BeeGeeks
A 1200 kg car is at a red light on a horizontal road. When the road turns to green, (t0) he starts accelerating and reaches 14 m/s in 7 seconds. He then continues at a constant speed for 10 seconds, then brakes with a -3.5 m/s^2 acceleration.
All accelerations are assumed to be constant.
a) Calculate the amount of time he spends decelerating. (What I found through graphing : 4 seconds)
b) Graph the speed in relation to time starting with t0. (Done successfully)
c) Calculate the average speed in both the acceleration and deceleration phase. (7 m/s)<- this seems weird to me)
d) Calculate the total distance between the start of the acceleration until the final stop.
I'm having trouble with point d).
The problem
I don't understand how we can calculate a distance while the object is under acceleration. I can't wrap my head around it. Is there an equation I don't know about? Or am I overcomplicating things and it's just ( for this problem) an additional 2 meters per second during the acceleration phase, then 10 seconds of adding 14 m per second and then decreasing the number you add to your total by 3 every second starting by 14 during your deceleration? is it that obvious?
Thanks in advance!
Why not? It's moving isn't it? What's the average speed during each segment of the motion? Use that to find the distance traveled.
Thanks!
Calculating distance while an object is under acceleration can be tricky, but it is possible using a few key equations. In this case, we can use the equation d = vt + 1/2at^2 to calculate the distance traveled during each phase of the car's motion.
During the acceleration phase, the car's initial velocity is 0 m/s and its final velocity is 14 m/s. We also know that the acceleration is 2 m/s^2 (since the car reaches 14 m/s in 7 seconds). Plugging these values into the equation, we get d = (14 m/s)(7 s) + 1/2(2 m/s^2)(7 s)^2 = 49 m + 49 m = 98 m.
During the constant speed phase, the car's velocity remains at 14 m/s for 10 seconds. Using the equation d = vt, we get d = (14 m/s)(10 s) = 140 m.
During the deceleration phase, the car's initial velocity is 14 m/s and its final velocity is 0 m/s. We also know that the acceleration is -3.5 m/s^2. Plugging these values into the equation, we get d = (14 m/s)t + 1/2(-3.5 m/s^2)t^2 = 14t - 1.75t^2.
Now, we can use the value we found for the time spent decelerating (4 seconds) to calculate the distance traveled during this phase. Plugging in t = 4, we get d = (14 m/s)(4 s) - 1.75(4 s)^2 = 56 m - 28 m = 28 m.
Therefore, the total distance traveled by the car is 98 m + 140 m + 28 m = 266 m.
I hope this helps to clarify the process of calculating distance while an object is under acceleration. It's important to remember to use the appropriate equations for each phase of motion and to pay attention to the units being used. Keep practicing and you'll become more comfortable with these types of problems in no time!
FAQ: Problem with distance in relation to acceleration.
What is distance?
Distance is a measure of how far an object has moved or the length of the path it has taken.
What is acceleration?
Acceleration is the rate of change of an object's velocity over time. It measures how quickly an object's speed or direction is changing.
How does distance affect acceleration?
Distance and acceleration are directly proportional. This means that the farther an object travels, the greater its acceleration will be.
What is the problem with distance in relation to acceleration?
The problem with distance in relation to acceleration is that it can be difficult to accurately measure or determine the distance an object has traveled. This can lead to errors in calculating acceleration.
How can the problem with distance in relation to acceleration be addressed?
The problem can be addressed by using precise measurement tools such as rulers, protractors, and timers to accurately measure distance and time. Additionally, using multiple trials and taking an average can help reduce errors in calculations.
