Problem with easy diffrential equation
  • Thread starter TheNaturalStep
  • Tags
    Diffrential
In summary, the conversation is discussing a differential equation problem involving a changing mass and a constant rate of change. The person explains how the equation should be written using LaTeX and points out inconsistencies in the notation used by the other person. They also suggest checking out a thread on Physics Forums for further clarification.
TheNaturalStep
Problem with an easy diffrential equation, the problem is explained in the picture ...
http://img209.imageshack.us/img209/7341/diffproblemsf9.jpg
Kindly TNS
You have
[tex]\frac{dm_p}{dt}= \dot{m_p_i}[/tex]
In that case
[tex]m_p= \dot{m_p_i}t[/tex]
would be correct only if [itex]\dot{m_p_i}[/itex] was a constant.
First, check out https://www.physicsforums.com/showthread.php?t=8997
So you can type the math notation in [itex] \LaTeX [/itex].
To see how I typed things in the "math" click on the images and you will see the code. It's very easy, and the preferable way to communicate.
Second,
So your equation is:
[tex] \frac{d m_p}{dt}= m_{pi} [/tex]
Now your teacher says that [itex] m_p = m_{pi}t [/itex].
You are saying this:
Let [itex] m_{pi} = m t^4 [/itex].
Then,
[tex] m_p = \frac{m_{pi} t}{5} [/tex]
You are not consistent with your notation. You should be careful here. For example, you introduce the variable [itex] m [/itex] and then it just disappears. However, with your argument you have:
Original:
You:
[tex] m_{pi} = m t^4 [/tex]
If we sub this in:
[tex] \frac{d m_p}{dt} = (m t^4) [/tex]
Now you say:
What happens if you differentiate this?
[tex] \frac{d m_p}{dt} = \frac{d \left( \frac{m_{pi} t}{5} \right)}{dt} = ? [/tex]
Related to Problem with easy diffrential equation
1. What is a differential equation?
A differential equation is an equation that involves an unknown function and its derivatives. It is used to model various physical, biological, and economic phenomena in the form of rates of change.
2. Why are differential equations important?
Differential equations are important because they provide a mathematical framework for understanding and predicting the behavior of dynamic systems. They are used in various fields such as physics, engineering, biology, and economics.
3. What is the difference between an easy and a difficult differential equation?
An easy differential equation is one that can be solved using simple and well-known techniques, such as separation of variables or substitution. On the other hand, a difficult differential equation may require more advanced and specialized methods to solve, making it more challenging.
4. How do I know which method to use to solve a differential equation?
The method to solve a differential equation depends on its type and complexity. Some common methods include separation of variables, substitution, and using an integrating factor. It is important to understand the characteristics of the differential equation and choose the appropriate method accordingly.
5. Can differential equations be solved analytically or numerically?
Yes, differential equations can be solved both analytically and numerically. Analytical solutions involve finding an exact expression for the unknown function, while numerical solutions involve approximating the solution using numerical methods and algorithms.
