Problem with gravity and masses
  • Thread starter atom888
  • Tags
    Gravity
In summary: Fine! I'll keep it as an souvenir. lolZ is a function of r. You can't say that Z is independent of r...basically, when r changes, Z changes. It's just like saying that y=Gx^2 but y doesn't change while x can, it's just completely nonsensical.
atom888
92
hi guys,
I was playing around with Newton Equation F=Gm1m2/r^2
I separate Fr^2 = Gm1m2 . This is bugging me. Fr^2 is a constant for a given 2 bodies(i call Z) of masses. That means that no matter what the distance r in between the two bodies, Z doesn't change. So i take my thought alittle further. Suppose the two bodies are almost infinite small with say ... 5 and 10 mass. so Z value is 50G. Since no matter how close u put them together, the value Z doesnt' change. I put them so close together that they almost like 1 body with a total mass of 15mass. Now I imagine what if they are 7 and 8 mass. The Z value is 56G. I put them throught the same process and let them come so close together that they're almost 1 body with 15mass. Now it looks like I have two identical bodies with different Z value. It seems disturbing.
but "Z" doesn't mean anything unless the bodies are separated and if you separate them in two different ways it shouldn't be surprising that you get two different "Z values".
I guess the question is... what does Z means. lol I imagine r^2 as a square and F go up and down to have a constant volume. Though I don't know what it means, but it seems unique.
it doesn't mean a thing besides G*M_1*M_2... which has only one value for a given M_1 and M_2 but may be different for different values of M_1 and M_2... even when M_1 + M_2 =M_tot is fixed, as you see in your example. but that, too, is meaningless.
FAQ: Problem with gravity and masses
What is the problem with gravity and masses?
The problem with gravity and masses is that our current understanding of gravity, as described by Einstein's theory of general relativity, does not fully align with our understanding of quantum mechanics. This creates a discrepancy between the macroscopic and microscopic worlds, making it difficult to fully understand and explain the behavior of gravity at all scales.
How does Einstein's theory of general relativity explain gravity?
Einstein's theory of general relativity describes gravity as the curvature of space and time caused by the presence of massive objects. This curvature is what causes objects to be attracted to one another and explains the force of gravity as we experience it on a large scale.
What is the role of mass in gravity?
Mass is the fundamental property that creates and responds to the curvature of space and time, resulting in the force of gravity. The larger the mass of an object, the greater its gravitational pull on other objects.
How does quantum mechanics affect our understanding of gravity and masses?
Quantum mechanics describes the behavior of particles and forces at the microscopic level. However, it does not fully align with our understanding of gravity, leading to the problem of reconciling the two theories. This is known as the "quantum gravity problem."
How are scientists working to solve the problem with gravity and masses?
Scientists are continuing to research and study the behavior of gravity and masses at both the macroscopic and microscopic levels. They are also exploring alternative theories, such as string theory and loop quantum gravity, in an attempt to unify the theories of general relativity and quantum mechanics.
