Problem with idempotent matrices
  • MHB
  • Thread starter Samme013
  • Tags
    Matrices
In summary: Thanks.In summary, the problem asks you to show that $I+A$ is invertible, using the fact that $(I+A)(I-\tfrac12 A)=I$.
Samme013
OK so i can prove that the given inverse is actually the inverse but i can not prove that I+A is non singular without using the given inverse so how do i go about doing that?(I have done part a)
Thanks in advance.View attachment 3586
I'm confused. Is there a reason you can't use the fact that $(I+A)(I-\tfrac12 A)=I$ in order to show that $I+A$ is invertible?
I am not sure if i can use that fact and i can't really ask but it is kind of trivial if i can use it.Is it even possible to show it without using that?
It might be. You might be able to do something clever with determinants. Let me marshall the facts such as we know them:
\begin{align*}
&\text{Idempotent matrices have determinant equal to } 0 \text{ or } 1. \text{ Why?} \\
A^2&=A \\
(\det(A))^2&=\det(A) \\
(\det(A))^2-\det(A)&=0 \\
\det(A)(\det(A)-1)&=0 \\
\det(A)&\in\{0,1\} \\
\therefore \; \det(I-A)&\in\{0,1\}. \\
&\text{Idempotent matrices are either the identity matrix, or are singular.} \\
&\text{Why? Assume } A \text{ is non-singular. Then } \\
A^2&=A \\
A^{-1}AA&=A^{-1}A \\
IA&=I \\
A&=I.
\end{align*}
Now we could take two cases: 1. $A=I$. 2. $\det(A)=0$.
For the first case, $I+A=I+I=2I$, and the determinant is $2^n\not=0$, where $A$ is $n\times n$.
For the second case, we have $\det(A)=0$. What if you formed the product
$$(I+A)(I+A)=I^2+IA+AI+A^2=I+2A+A=I+3A.$$
Not sure where that leads you. You could also form
$$(I-A)(I+A)=I^2+IA-AI-A^2=I+A-A-A=I-A.$$
Just seeing here:
$$(I-A)(I-A)=I^2-IA-AI+A^2=I-A-A+A=I-A.$$
Evidently, $(I-A)(I-A)=(I-A)(I+A)$, but I don't see where you can go further. There's no guarantee that $I-A$ is invertible (indeed, unless $I-A=I$, it won't be!), so you can't cancel anything, and the determinants won't give you anything here, either.
I think that using the formula for the inverse the problem asks you to show is just fine. If you simply compute $(I+A)(I-\tfrac12 A)=I$, you have just shown that $I+A$ is invertible. The problem asks you to show those two things. It does not tell you in what order to do them.
\begin{align*}
A^2&=A \\
A^2&=A \\
IA&=I \\
A&=I.
\end{align*}
Just seeing here:
The exercise is listed under a chapter which is before determinants are introduced( i have no clue what they are yet) so most likely it is not expected to come up wit that solution.I will definitely come back and take a look at this when i get to the next chapter though, thanks for helping !
You're very welcome!
FAQ: Problem with idempotent matrices
What is an idempotent matrix?
An idempotent matrix is a square matrix that, when multiplied by itself, results in the same matrix. In other words, the matrix raised to any power greater than or equal to 1 will always be equal to itself.
What causes problems with idempotent matrices?
The main problem with idempotent matrices is that they can have multiple solutions for the same equation, making it difficult to find a unique solution. This can lead to confusion and errors in calculations.
How are idempotent matrices used in real life?
Idempotent matrices have various applications in fields such as computer science, economics, and physics. They are used in data compression, optimization problems, and modeling physical systems, to name a few examples.
Can any matrix be idempotent?
No, not all matrices can be idempotent. For a matrix to be idempotent, it must have certain properties, such as being square and having all eigenvalues of 0 or 1. In addition, the matrix must not be invertible.
How do you solve problems involving idempotent matrices?
To solve problems involving idempotent matrices, one must carefully consider the properties of the matrix and use appropriate methods to find solutions. This may involve using eigenvalues and eigenvectors, matrix decompositions, or other techniques depending on the specific problem.
