Problem with Lock-in Amplifier (cannot lock the signal)
In summary: One other thing to try is the coupling of the input signal=be sure it is not saturated with a +12 volt DC signal. AC couple the input if necessary. Also, make sure you are using the "f" frequency mode and not "2f". Also, you might try putting in a stronger input (square wave from photodiode) signal and make sure you adjust the phase to maximize the output signal. It is certainly possible the lock-in amplifier has electronic problems of some kind. One other thing you could try that occasionally can be problematic is your coaxial cables=occasionally they can malfunction, especially the connectors=try inter
Sotiris
Hello, I'm using a lock in amplifier (model 5210 from signal recovery) for some experiments with photodiodes. Firstly, there is an optical chopper that "feeds" the lock in (reference signal). My input is a photodiode (in current mode). The problem is,the unlock (unlk) light is always on in the lock in amplifier, but, in the display section, i can see the reference frequency from the chopper. However, it was working well in previous experiments, as my professor stated. I tested the exiting signal from the chopper with an oscilloscope and it is the right one. Also, everything else in the lab is tested and working well. So, my question is, is it possible that something in the lock in isn't working?(i'd guess it's the mixer) I'm sorry if the question is dumb or something, I don't have any previous experience with the lock in and I'm desperate. Any other ideas would be appreciated.
It's been a while since I used that type of lock-in amplifier, but as I recall, there may have been a couple of buttons to select the reference input=(not sure about this, because it's been a while.) I seem to recall an "external" reference button might need to be pushed in or selected to get the reference signal to work. Anyway, that might be worth trying. If your reference signal is healthy and steady, the other possibility is that the lock-in amplifier is malfunctioning. Another thing that might be worth trying is the type of coupling to the reference signal if you have that option available on the lock-in amplifier. e.g. if the chopper reference is all positive, like it is for some models, you could try ac coupling to the reference signal if that selection is available. Also, you might try using a "T" to observe the chopper reference signal on an oscilloscope at the same time that you have it feeding into the lock-in amplifier. It is possible it is getting loaded down by a failed component in the lock-in, etc.
Likes Sotiris
Thanks for your reply. The external button is active because the lock in is showing the chopper's frequency as reference. Also, the chopper's output is already ac. The last suggestion was interesting, i tried it and the signal was indeed healthy and steady, but the output of the lock in is either random noise, or some crazy lines, or a "no signal" message.
One other thing to try is the coupling of the input signal=be sure it is not saturated with a +12 volt DC signal. AC couple the input if necessary. Also, make sure you are using the "f" frequency mode and not "2f". Also, you might try putting in a stronger input (square wave from photodiode) signal and make sure you adjust the phase to maximize the output signal. It is certainly possible the lock-in amplifier has electronic problems of some kind. One other thing you could try that occasionally can be problematic is your coaxial cables=occasionally they can malfunction, especially the connectors=try interchanging them. If you still can't get the lock-in to give a good output, it is likely the lock-in has malfunctioned. One more item=make sure the frequency of the chopped signal (especially the chopper reference) is very steady=if it wavers in frequency, the lock-in might have trouble locking in on it. You might want to try using a different chopper before you conclude that the lock-in has failed.
Likes Sotiris
For now, i know that the input is not saturated for sure, and the lock in is in "f" mode. I'll try to adjust the phase and replace the cables tomorrow. Another thing that i noticed, is that in the oscilloscope the chopper's signal is very steady, but in the lock in, many times it differs (for example, if the chopper is at 80 Hz, the lock in is showing 79.9 and 80 and this is changing frequently, but i don't know if this error is significant enough to make this kind of problem)
Likes Charles Link
I tried again today, nothing worked. The next step is to open open the lock in in case we find something odd with the board that can be fixed. Your suggestions were thorough enough, thanks again. I'll post what happened when we find out.
Likes Charles Link
Generally you can get quite a lot of use out of the various electronic equipments, but on occasion they do fail and need to be replaced.
FAQ: Problem with Lock-in Amplifier (cannot lock the signal)
1. What is a lock-in amplifier and how does it work?
A lock-in amplifier is an electronic device that is used to extract a small signal that is buried in noise. It works by multiplying the input signal with a reference signal, filtering the resulting product, and then measuring the output. This process allows for the detection of weak signals that would otherwise be masked by noise.
2. Why am I having trouble locking the signal with my lock-in amplifier?
There could be several reasons for this issue. One common reason is that the reference signal is not properly synchronized with the input signal. Another possibility is that there is too much noise in the system, making it difficult for the lock-in amplifier to distinguish the signal. It is also possible that there is a problem with the amplifier itself, such as a faulty component or incorrect settings.
3. How can I improve the signal-to-noise ratio in my lock-in amplifier?
There are a few ways to improve the signal-to-noise ratio in a lock-in amplifier. One way is to increase the integration time, which allows the amplifier to average out noise over a longer period. Another option is to use a larger reference signal, which can increase the strength of the signal relative to the noise. Additionally, ensuring that the signal and reference are synchronized and that the amplifier is properly calibrated can also improve the signal-to-noise ratio.
4. Can I use a lock-in amplifier for any type of signal?
Lock-in amplifiers are best suited for detecting weak signals that are buried in noise. They are commonly used in scientific research for signals such as low-frequency AC, optical, and RF signals. However, they may not be as effective for detecting signals with high frequency or amplitude, as they are more sensitive to noise in these cases.
5. Are there any alternative methods for detecting weak signals besides using a lock-in amplifier?
Yes, there are other methods for detecting weak signals, such as using a high-gain amplifier or a spectrum analyzer. However, lock-in amplifiers are often preferred because they can extract signals with very low signal-to-noise ratios and are more versatile in their applications.
