Problem with molecular separation calculations
In summary, the problem involves estimating the average separation of molecules of hydrogen at STP (gas), in water (liquid), and in iron (solid) using data from Table 2-1 and A-1. The relevant density values are given for each substance. The attempt to solve the problem using spherical and cubic geometry is shown, but the answers do not match those in the book. After further rethinking, a new approach using the mass and volume of a hydrogen molecule is proposed, resulting in a more accurate answer.
emjay66
I am attempting to complete a basic question involving molecular separation from Alonso & Finn "Fundamental University Physics" Second Edition, Chapter 2, Question 9. The Problem states
"Using the data in table 2-1 and A-1, estimate the average separation in molecules of hydrogen at STP (gas), in water (liquid), and in iron (solid)."
Now, Table 2-1 contains density values (relative to water). The relevant values are:
Iron = 7.86
Water (4 Degrees C) = 1.000
Hydrogen = [itex]8.988\times 10^{-5}[/itex]
Table A-1 is the periodic table of the elements and the relevant values for this are:
Hydrogen = 1.00797
Oxygen = 15.9994
Iron = 55.847
I will only show my attempt to compute the answer for Hydrogen since I feel I am (probably) making the same mistake throughout.
An inspection of the answers in the back showed that for Hydrogen they obtained:
3.39*10^-7 cm for spherical geometry and 1.14 * 10^-8 cm for cubic geometry
Firstly I assume a Hydrogen "molecule" is two atoms of Hydrogen
I also assume the calculation for a mass of 1kg of the relevant substance
the molecular mass of a Hydrogen molecule = 2 * 1.00797 = 2.01594 g/mol
Number of mole of Hydrogen in 1kg = 1000/2.01594 496.047 mol
Number of Hydrogen molecules = 496.047 * (6.02*10^23) = 2.986*10^26 molecules
Number of Hydrogen molecules at STP = 2.986*10^26 * (8.988*10^(-5)) = 2.68*10^22 molecules
At this point (for a cube) I know 1kg = 1000 cubic centimetres
which means the cube root of 2.68*10^22 (= 29940610.46) would give the number of molecules along one edge (10cm)
which (to me) would mean that 10/29940610 = 3.34*10^(-7) cm, which is clearly wrong.
For the Spherical geometry I reasoned [itex]1000 = \frac{4}{3}\pi\,r^3 [/itex] which would mean [itex]r = (\frac{3000}{4\pi})^{1/3} [/itex] = 6.2 cm which means the diameter would be
12.4 cm. This would give a separation of 4.4*10^(-7) cm, which is also wrong.
I understand that my thinking is clearly faulty, so some pointers in the right direction would be nice. Thank you in advance.
Why is that clearly wrong?
I only feel my approach is wrong or incomplete because my answers do not match those contained at the back of the text (also stated in the original email above). Unfortunately I have no other assertion to base it on. (ps I was a little rushed with my OP so I apologise if that wasn't entirely clear)
Did you notice that the book answers to b) and c) both have spherical < cubic ?
Perhaps you should try those and see what you find!
What does the book give as an answer? I get a slightly different answer than yours when considering that each molecule occupies a sphere, but you have the correct answer when considering the volume to be cubic.
See also https://www.physicsforums.com/showthread.php?t=394617
Ok the answer for each (in the back of the book) are as follows (in spherical, cubic) order (all numbers are cm):
Hydrogen: 3.29*10^-7, 1.14*10^-8
Water: 3.85*10^-8, 6.21*10^-8
Iron: 2.82*10^-8, 4.46*10^-8
Some rethinking about the problem gave me the following:
mass of Hydrogen molecule = (2*1.00797)* 1.6606*10^-27 = 3.35*10-27kg = 3.35*10^-24g
if Density of Hydrogen at STP = 8.988*10^-5 g cm^-3 then Volume = 3.35*10^-24/8.988*10^-5 = 3.72*10^-20cm-3
Assuming the Hydrogen molecule is a sphere, then 3.72*10^-20 = 4/3 * pi * r^3 which means r (radius of Hydrogen molecule) = 2.07*10^-7 cm which means the diameter is approximately 4.14*10^-7 cm
Number of molecules of Hydrogen in 1kg = 2.684*10^19 (as before)
which is equivalent to (2.684*10^19)^(1/3) which is approximately 3*10^6 along one 10cm edge
This means that 3*10^6 molecules would occupy (with no gaps) 3*10^6*4.14*10-7 which is app 1.24 cm
leaving 8.758cm to be used as gaps for 3*10^6 molecules. This would mean that the inter molecule gap is 8.758/3*10^6 = 2.9*10^-6 cm for a cube
For a sphere I use the Wigner-Seitz approximation (with n = 3.72*10^-10cm^-3) which would give a inter molecule gap of 2.07*10^-7 cm.
I will post my other rework later.
Related to Problem with molecular separation calculations
1. What is molecular separation?
Molecular separation is the process of separating and purifying molecules from a mixture. This is often done in industries such as pharmaceuticals, food and beverage, and chemical manufacturing.
2. What are some common problems with molecular separation calculations?
Some common problems with molecular separation calculations include inaccuracies due to assumptions made about the mixture, variations in the composition of the mixture, and errors in measurement or experimental conditions.
3. How do you perform molecular separation calculations?
Molecular separation calculations involve using mathematical equations and principles such as mass balance, equilibrium constants, and thermodynamics to determine the optimal conditions for separating and purifying molecules from a mixture.
4. What is the role of computer simulations in molecular separation calculations?
Computer simulations play a crucial role in molecular separation calculations by allowing scientists to model and predict the behavior of molecules in a mixture under different conditions. This helps in identifying the most efficient and cost-effective separation processes.
5. How can I ensure the accuracy of my molecular separation calculations?
To ensure the accuracy of molecular separation calculations, it is important to use reliable and precise measurement techniques, validate assumptions made about the mixture, and perform multiple trials under different conditions. It is also helpful to consult with other experts in the field and compare results with existing literature.
9K
  • Atomic and Condensed Matter
25K
