I Problem with notation of matrix elements
  • I
  • Thread starter Thread starter Lambda96
Lambda96
TL;DR Summary
What does this notation ##A_{\quad i}^j## and ##A_i^{\quad j}## mean?
Hi,
In one of my assignments, we had to prove that the Frobenius product corresponds to a complex scalar product. For one, we had to prove that the Frobenius product is hermitian symmetric.
I have now received the solution to the problem, and unfortunately I do not understand the notation for the individual matrix elements. I only know the notation ##a_{ij}## but what does it mean when one of the indices is written with a space of A or B, what is this space about? What should be the row and what the column in this kind of notation?
Here is the solution
Lambda96 said:
TL;DR Summary: What does this notation ##A_{\quad i}^j## and ##A_i^{\quad j}## mean?
Hi,
It is called Einstein notation or Einstein summation. Physicists use it all the time.
https://en.wikipedia.org/wiki/Einstein_notation
You can deconstruct it by the image you posted.
\begin{align*}
(A^\dagger B)_{ij}&=\sum_{k=1}^n (A^\dagger )_{ik}\cdot B_{kj} =\sum_{k=1}^n (\overline{A_{ki}})\cdot B_{kj}\\
\operatorname{trace}(A^\dagger B)&=\sum_{p=1}^n (A^\dagger B)_{pp}\\
&=\sum_{p=1}^n \left(\sum_{k=1}^n (\overline{A})_{kp}\cdot B_{kp}\right)\\
&=\sum_{j=1}^n \left(\sum_{i=1}^n (\overline{A})_{ij}\cdot B_{ij}\right)\\
&= (\overline{{A_j}^i})\cdot {B^j}_i
\end{align*}
It is an abbreviation for the summation. Summed is over the indices that occur on top and at the bottom, here twice: sum over ##i## and sum over ##j##.
Likes Lambda96 and PeroK
Hi,
If in an assignment you encounter a notation that you have never seen before, then there must be a serious disconnection between your course syllabus and what you are studying.
Thanks fresh_42 for your help 👍
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
