Problem with proof of elastic energy
In summary, the homework statement discusses how to solve for elastic energy using the formula W=Fx. The problem is that the author is not clear on how F and K relate to one another. The author also provides a more precise proof that depends on understanding that W=F⋅S.
ffrog
How do i prove 0.5kx2=elastic energy?
Energy in= Energy out
I understand how to use the formula but what i don't understand is where the formula comes from. I am guessing it has to do with Fx=Kx but am unsure how K=F then.
The work done can be expressed as
W=Fs
Where F is the force and s is the distance through which the force acts. Since we have a spring we can write this as
W=Fx
Where x is the elongation
Since the force F depends on the elongation (remember F.spring=kx. In other words, when we pull the spring the elongation gets larger and thus we are required to use an even larger force to pull the spring more), the averaga force acting through "x" is
F.average=(0+kx)/2Combining both expressions yields
W=0.5kx^2
thankyou very much problem solved i think i may stick around help afew people out here
A more precise proof depends on understanding that W = F⋅S as mentioned.
With a spring, however, you have a variable force over the length of its application. So you must use then
PE = W = ∫ F⋅S ds
For F = -kx then
W = ∫ F⋅S ds = ∫ -kx dx = -1/2kx2 evaluated from 0 to x
i think i iwill stick with the first one its good enough for me but the secound one makes sense so thanks.
FAQ: Problem with proof of elastic energy
What is elastic energy and why is it important in scientific research?
Elastic energy is the potential energy stored in an elastic material when it is stretched or compressed. It is important in scientific research because it can be converted into other forms of energy and is a fundamental concept in fields such as mechanics and thermodynamics.
What are some common problems with proving the existence of elastic energy?
One common problem is accurately measuring the amount of elastic energy in a material, as it can be difficult to isolate and quantify. Another issue is determining the source of the elastic energy, as it can come from various factors such as molecular bonds or external forces.
How does elastic energy play a role in everyday life?
Elastic energy is present in many everyday objects and activities. For example, it allows for the bouncing of a ball, the stretching of a rubber band, and the compression of a spring. It also plays a role in the functioning of muscles and tendons in the human body.
Can elastic energy be harnessed for practical use?
Yes, elastic energy can be harnessed for practical use in various ways. One example is in the design of efficient machinery and structures that utilize elastic materials. It can also be converted into other forms of energy, such as kinetic energy, to power devices.
How does the concept of elastic energy tie into the larger study of thermodynamics?
Elastic energy is a key concept in thermodynamics, which is the study of energy and its transformations. It is closely related to the concepts of work, heat, and potential energy, and is an important factor in understanding the behavior of materials and systems in thermodynamic processes.
