Problem with solving an equation
  • Thread starter Parashurama
In summary, the conversation discusses finding a formula for the x value needed to create a box with a fixed volume by cutting away corners from a square. The formula V=x(50-2x)^2 is used, but there are difficulties in isolating x. The solution is to use tables to narrow down the desired volume.
Parashurama
I have a square 50x50 units. I want to make a pool(box without a lid), and then cut away the corners. The "corner-square" is x^2.
What I want is a formula X(v) that gives me the x value needed to get a fixed volume.
The V(x) function is base x height, x(50-2x)^2. But i have problems isolating x based on this formula.
If i try solving it in Maple I get:
25/2 + 1/2sqrt(625-2v) and 25/2 - 1/2sqrt(625-2v)
but this makes no sense to me.
I've calculated the max volume at x=25/3 to be 250000/27, and the function is only valid from x=0..25.
I guess the answers Maple gives me is because it does not know og my 0..25 range, but I don't know how to make that part of the calculation.
If the problem is unclear, please say so and I will try to explain better.
If each side is 50 and you "cut away" [itex]x^2[/itex] from each corner then you base will have sides of length 50- 2x. The base will have area [itex](50- 2x)^2[/itex] and the box will have height x. The volume is [itex]x(50- 2x)^2[/itex].
Now, what is it you specifically want to do? Solve [itex]x(50- 2x)^2= v[/itex] for any v? Multiplying out the left side gives [itex]4x^3- 200x^2+ 2500x= v[/itex] or the cubic equation [itex]4x^2- 200x^2+ 2500x- v= 0[/itex]. Your "Maple" solution looks like a quadratic formula- you may have left out an "x".
Thanks for answering!
What I want is a function that gives me the x value needed to make a box with a cirtain volume.
I will check my equations in Maple tonight, when I get back from work.
I did leave out an x, but still did not get a sensible answer. But when I read the problem text once more a saw that I was not supposed to make a formula, but use the formula V=x(50-2x)^2 and use tables to narrow down to the volume you needed.
So the problem is solved that way and that I figuerd out :P
Thanks for the help!
FAQ: Problem with solving an equation
What is the most common mistake when trying to solve an equation?
The most common mistake when solving an equation is forgetting to perform the same operation on both sides of the equation. This can lead to an incorrect solution.
How do I know if my solution to an equation is correct?
To check the solution to an equation, you can plug the solution into the original equation and see if it satisfies the equation. If it does, then your solution is correct.
What is the difference between an identity and an equation?
An identity is an equation that is true for all values of the variable, while an equation is only true for specific values of the variable.
Can an equation have more than one solution?
Yes, an equation can have multiple solutions. These solutions can be represented as a set of numbers or an interval on the number line.
How do I solve an equation with variables on both sides?
To solve an equation with variables on both sides, you can start by combining like terms on each side, then move all the variable terms to one side and all the constant terms to the other side. Finally, solve for the variable by isolating it on one side of the equation.
