Problem with taking the divergence
  • Thread starter lavster
  • Tags
    Divergence
In summary, the conversation is discussing how to take the divergence of a function and the results of using the spherical coordinate system. The divergence theorem is also mentioned, with a comparison between the volume integral in two different cases and the properties of the 3D Dirac Delta function.
lavster
217
hi, can someone tell me how [itex]\nabla\dot(\frac{\widehat{r}}{r^2})=4\pi\delta^3(r)[/itex]
thanks
thanks
How would you normally proceed with taking the divergence? What coordinate system is this in?
i would use spherical coord system. using the corresponding form of div. but this gives 0 as the r^2 in the formula is canceled but the r^2 in the div eqn
Sure, it gives zero everywhere, except at r=0. Remember, [itex]\frac{1}{r^2}[/itex] is undefined at [itex]r=0[/itex]:wink:
What does the divergence theorem tell you about the volume integral
[tex]\int_{\mathcal{V}}\left(\mathbf{\nabla}\cdot\frac{\hat{\mathbf{r}}}{r^2}\right)dV[/tex]
in two cases:
(1) When [itex]\mathcal{V}[/itex] is any volume enclosing the origin?
(2) When [itex]\mathcal{V}[/itex] is any volume not enclosing the origin?
Compare these results, along with the fact that [tex]\mathbf{\nabla}\cdot\frac{\hat{\mathbf{r}}}{r^2}[/itex] is zero everywhere except at [itex]r=0[/itex], where it is undefined, to the properties defining the 3D Dirac Delta function.
FAQ: Problem with taking the divergence
What is the divergence of a vector field?
The divergence of a vector field is a measure of the rate at which the field's magnitude is changing at a given point. It is represented by the dot product of the gradient operator and the vector field.
Why is taking the divergence important in science?
Taking the divergence of a vector field allows us to understand how the field is changing at a particular point, which can help us analyze the behavior and properties of the field. It is commonly used in fields such as fluid dynamics, electromagnetism, and thermodynamics.
What are the conditions for taking the divergence of a vector field?
The vector field must be defined and continuous in the region of interest, and the partial derivatives of its components must exist and be continuous.
How is the divergence related to the concept of flux?
The divergence is closely related to the concept of flux, which is the amount of a vector field that is flowing through a given surface. The divergence at a point can be interpreted as the amount of flux per unit volume that is entering or leaving that point.
Can the divergence of a vector field be negative?
Yes, the divergence of a vector field can be either positive, negative, or zero. A positive divergence indicates that the field is spreading out from a point, while a negative divergence indicates that the field is converging towards a point. A zero divergence indicates that the field is neither spreading nor converging.
