B Problem with the concept of differentiation
rudransh verma
TL;DR Summary
What is the change actually at some time ##t_0##?
We define differentiation as the limit of ##\frac{f(x+h)-f(x)}h## as ##h->0##. We find the instantaneous velocity at some time ##t_0## using differentiation and call it change at ##t_0##. We show tangent on the graph of the function at ##t_0##. But after taking h or time interval as zero to find the instantaneous change there is no two points left for change to occur. Change at ##t_0## is meaningless in the same way as the slope at a point. How can there be a change at say 5 sec? We have to take two points to talk about change in between them.
We never take h=0, we take the limit as h approaches zero. This is a well-defined process which is easy to understand. You say, "there is no two points left for change to occur". Remember that no matter how small the interval between two points, there are always an infinite number of points between them. So we can continue calculating f(x+h) - f(x) no matter how small h is.
Likes SolarisOne, WWGD, russ_watters and 2 others
https://www.feynmanlectures.caltech.edu/I_08.html
See this part below of velocity at t in the link above. Clearly when finding limit we take ##\epsilon= 0##
Let’s take an example. Find lim x->3 ##\frac{x^2-9}{x-3}##
Lim ##(x-3)(x+3)/(x-3)##
Taking x=3, limit is 6.
Don’t get me wrong but I am not getting it. We do put value of say ##\epsilon=0## to find the limit. Why do we do that?
Is it has to do with what you said that we can take smaller and smaller values of h and find more accurate value of rate. So we can see where does this value tend if we make h very very small. That will be the value of rate at precisely a point.
Another definition would simply the slope of the tangent vector of f(x) at point x
Here you can do that, because the function ##f(x) = \frac{x^2-9}{x-3}## has a removable singularity at ##x=3##. So, in fact, you still take a limit (albeit somewhat implicitly) to demonstrate that ##f##, at first not defined for ##x=3## can be extended to a continuous function ##\tilde{f}## that is defined on the whole real line. Next, you indeed just evaluate ##\tilde{f}## in ##x=3##.
Of course, normally you do not spend this much prose and just write it as you did in the first place.
This is of course true, but maybe it is good for the OP to know that it took mathematicians quite a bit of time to make this step from the difference quotient to the differential quotient. So, conceptually it is not at all a trivial step.
to the OP: you are entirely correct. change does not make sense at one point. the derivative is a concept useful for approximating actual changes between 2 points, but without knowing exactly which two points will be chosen. given one point, we want a number which will give us the approximate change from that point to any nearby second point, so that approximation will get better as the second point is chosen closer to the first, (in a precise sense encoded by the definition of limit). I.e. if you decide how good an approximation you want, there will be an interval of choices for the second point, such that the approximation will satisfy your requirement for every point in this interval. then the derivative is the unique number doing this job.
Likes rudransh verma
vela said:
https://www.physicsforums.com/threa...antaneous-rate-of-change.1011395/post-6588946
S.G. Janssens said:
Here you can do that, because the function f(x)=x2−9x−3 has a removable singularity at x=3. So, in fact, you still take a limit (albeit somewhat implicitly) to demonstrate that f, at first not defined for x=3 can be extended to a continuous function f~ that is defined on the whole real line. Next, you indeed just evaluate f~ in x=3.
This was missing in my book and nobody tells it. Just go and solve the problem.
Can you show me an example because all we are saying for example in my post#3(see attached image) is ##v(t_0)=32t_0##. We are screaming that rate of change at ##t_0## is ##32t_0##.
Actually, we call this the velocity or instantaneous velocity at time ##t_0##. A good way to think about this is that the speedometer in a car shows you the instantaneous velocity -- the velocity at a particular moment. This is different from the average velocity, which is calculated by the distance traveled divided by the elapsed time. IOW, like this:
$$\frac{s(t_0 + h) - s(t_0) }h $$
Slope at a point is not meaningless. Imagine you are a small insect traveling along the path of some curve. The slope of the tangent line at some point on the curve is in exactly the same direction you would be looking.
You're not looking for a change, though. You're looking for the rate of change. While it doesn't make sense to talk about a change at a single point in time, it does make sense to talk about the rate of change at an instant.
Likes benorin and Drakkith
Let ##x_1< a<x_2## and ##f:(x_1,x_2)\backslash\{a\}\to\mathbb{R}## be a function.
Def. We shall say that ##\lim_{x\to a}f(x)=A## iff for any ##\varepsilon >0## there exists ##\delta>0## such that
$${\bf 0<}|x-a|<\delta\Longrightarrow |f(x)-A|<\varepsilon$$
Likes benorin
wrobel said:
Let me say it again: never never use physics textbooks for studying math.
There's nothing wrong with Feynman here. This is what Feynman says:
The true velocity is the value of this ratio, x/ϵ, when ϵ becomes vanishingly small. In other words, after forming the ratio, we take the limit as ϵ gets smaller and smaller, that is, approaches 0.
He says that ϵ becomes vanishingly small, he says that ϵ gets smaller and smaller, he says that ϵ approaches 0. He never, ever, ever says that we set ϵ equal to 0, so @rudransh verma how is it possible for you to read these words and say:
Likes benorin
Feynman provides two examples for ## t_0 = 5 \ \tt{s} ## in the passage you linked:
We know where the ball was at 5 sec. At 5.1 sec, the distance that it has gone all together is 16(5.1)2=416.16 ft (see Eq. 8.1). At 5 sec it had already fallen 400 ft; in the last tenth of a second it fell 416.16−400=16.16 ft. Since 16.16 ft in 0.1 sec is the same as 161.6 ft/sec, that is the speed more or less, but it is not exactly correct. Is that the speed at 5, or at 5.1, or halfway between at 5.05 sec, or when is that the speed? Never mind—the problem was to find the speed at 5 seconds, and we do not have exactly that; we have to do a better job. So, we take one-thousandth of a second more than 5 sec, or 5.001 sec, and calculate the total fall as
## s=16(5.001)^2=16(25.010001)=400.160016 \tt{ft}. ##
In the last 0.001 sec the ball fell 0.160016 ft, and if we divide this number by 0.001 sec we obtain the speed as 160.016 ft/sec.
I did not say "wrong". I just gave an advise not to study math. by physics textbooks. If this is not obvious compare what (and how) Feynman says and what (and how) Serge Lang says:
I understand that ##0<|x-a|## meaning x is not equal to a but what is the meaning of ##|x-a|<\delta##.
Likes benorin
Not really, it is equivalent to ## x \ne a ## (when x and a are real numbers) but its meaning is "0 is less than the magnitude of ##x - a##".
"the magnitude of ## x - a ## is less than ## \delta ##".
pbuk said:
Not really, it is equivalent to ## x \ne a ## (when x and are real numbers) but its meaning is "0 is less than the magnitude of ##x - a##"."the magnitude of ## x - a ## is less than ## \delta ##".
I mean I am unable to correlate it to the definition of limit.
Does it mean if we keep decreasing ##\epsilon## such that f(x) gets closer to A there exist ##\delta## such that x gets closer to a?
Are you referring to this definition of a limit?
What this definition says is that ## A ## is the limit of ## f(x) ## at ## x = a ## if and only if for every value of ## \varepsilon > 0 ## you can find a circle of radius ## \delta ## around ## x = a ## within which ## | f(x) - A | < \varepsilon ##.
pbuk said:
What this definition says is that A is the limit of f(x) at x=a if and only if for every value of ε>0 you can find a circle of radius δ around x=a within which |f(x)−A|<ε.
Does it mean if we keep decreasing ϵ such that f(x) gets closer to A there exist δ such that x gets closer to a?
I understand that 0<|x−a| meaning x is not equal to a but what is the meaning of |x−a|<δ.
By other words this means the following. Let $$B_r(x_0):=\{x\mid |x-x_0|<r\};\quad \dot B_r(x_0)=B_r(x_0)\backslash\{x_0\}.$$ Equivalently the definition is sounds as follows
For any ##\varepsilon>0## there exists ##\delta>0## such that
$$f(\dot B_\delta(a))\subset B_\varepsilon(A).$$
I think it depends what aspect about the math you're interested in. If you're trying to get an intuitive understanding of what the math means, a physics book may be better. The emphasis on proofs and rigor in math books can obscure what the math means in an intuitive sense.
I started taking a graduate math course in differential geometry when I was in grad school. The professor was trying to convey an intuitive understanding of what he was talking about to the students, and at one point, he stopped and asked if the students understood what he was trying to say. All the math students shook their heads. Then he looked at the physics students and asked if we got what he meant, and we all nodded.
Frankly, I think a combination is the best approach. Physicists can appear to play fast and loose with the math at times, but you do get a sense of what the point of the math is. Then seeing the rigor of mathematicians can help you learn to avoid playing too fast and too loose.
Yes it can. But I think that if one has an intuitive understanding but does not have a formal definition then one has nothing.
Likes S.G. Janssens
I thought that this was a mistake but now I think it will be ok. I do that sometimes to avoid the boringness of maths. It is always fun to watch how we get to prove something in physics and to do that we just have to know how it’s done. No need to go into derivations of maths. I don’t like solving maths problems very much because it doesn’t take you anywhere like physics does.
Frankly That definition was better. Can you verify what I am trying to say whether it’s correct?
@rudransh verma: as an example, if f(t) = 16t^2, then what you are calling the rate of change "at a", is 32a. I am saying that this simply means that for all t near a, the actual rate of change between the 2 points a and t, namely [16t^2-16a^2]/(t-a) = 16(t+a), is approximately 32a. And this approximation has an error of 16(t+a) - 32a = 16(t-a), and this error is as small as you like, for t near enough to a. I.e. for all t near a, the actual rate of change between t and a, is approximately 32a. And 32a is the only number that approximates all those actual rates of change, with an error that goes to zero as t goes to a.
No. You're missing the key part of it. It says that as we keep decreasing ε such that f(x) gets closer and closer to A, we can always find a δ such that |x-a| < δ implies that |f(x)-A| < ε.
Likes benorin
It means what it says. That the absolute value of the difference between the numbers ##x## and ##a## is less then the number ##\delta##.
  • #31
@rudransh verma: another way to look at the derivative of f at a, is as the coefficient of the best linear approximation to the actual change function f(t)-f(a). I.e. if you can find a number D such that the change function f(t)-f(a) is well approximated by the linear function D.(t-a), then D is the derivative of f at a. By "well approximated" we mean the error term is a function vanishing to higher order than one, which means the change function f(t)-f(a) equals D.(t-a) + e(t).(t-a), where e(t) approaches zero as t approaches a. (Then the product e(t).(t-a) approaches zero faster than order one, as t appoaches a, since both factors approach zero.)
I.e. if we can write the change function f(t)-f(a) = (D+e(t)).(t-a), where D is a number and e(t) is a function such that e(t)-->0 as t-->a, then the change function f(t)-f(a) is well approximated by the linear function D.(t-a), for points t near a, and D is the derivative of f at a. I.e. the derivative of f at a, is the coefficient of the best linear approximation to the changes in f, between a and all points t near a.
Since f(t)-f(a) is well approximated by D.(t-a), also f(t) is well approximated by f(a) + D.(t-a), and the graph of f is well approximated by the graph of f(a) + D.(t-a), which is nothing but the tangent line to the graph of f, at a. So also the derivative of f at a, is the (lead) coefficient of the unique linear function whose graph is tangent to the graph of f, at a.
i have given several precise and meaningful descriptions of the derivative, but one may ask also what is the physical meaning? To me there is in fact no physical meaning to the derivative. I believe it has only mathematical meaning. But some authors wanting to give it some intuitive physical meaning, by extending the familiar meaning of rate of change, may ask us to imagine an infinitely small change in t, and the corresponding infinitely small change in f(t), and call the derivative the corresponding (finite) "infinitesimal rate of change of f at a". To me this is mostly nonsense, but I do not think one should entirely dismiss this sometimes useful "nonsense", but should try to make some attempt to come to terms with it. I am still trying.
Likes ergospherical
  • #32
That has already been said
  • #33
In spite of my comments above, here is an attempt to give some physical meaning to the derivative of the motion of a particle. Imagine whirling a rock tied to a string, around your head. Then at a certain instant release the string from your hand. In some sense, the derivative of the motion, at the instant of release, is given by the, roughly straight, i.e. linear, path of the rock after being released. I.e. after removing the accelerating force, the path is determined by the "instantaneous velocity" of the rock at the instant of release. (Of course there is still friction, and gravity, but this is the best I can do to render the "instantaneous velocity" visible.)
  • #34
You mean like v=32t. Here the v at 5sec is 160ft/s and it will be approximately 160 around 5sec with some error. So we will be able to calculate approximate actual changes between two nearby points. we say the velocity of body from say 5sec to 5.000001 sec is approximately 160ft/sec. In this way we can calculate the approximate change of position in between them as 0.00016 ft.
We can take any value of t and approximate the actual change between t and some near point assuming nothing unexpected happens.
because the velocity keeps on changing. Right? That’s why “approximate change” and not exact change.
Let’s say 160.016 ft/s is good enough. I got that speed by taking my other point as 5.001sec. So now this approximation works for many points near 5.001 hoping there is no any sudden major changes in speed. Points like 5.01sec,5.03sec,etc
In the same way if we take the limit we get precisely 160 at 5. This is very exact than 160.016 ft/s. Now this works for points near 5. Right!
  • #35
Yes, I think you are getting it. I tried to think of another way, inspired by your example, of the physical meaning of instantaneous velocity. Suppose an object is dropped on you from rest and from a height of 400 feet above your head. Then when it hits your head 5 seconds later, its instantaneous velocity will be exactly 32t = 32(5) = 160 feet per second, which gives it momentum at that instant of 160 times the mass of the object. Thus the instantaneous velocity at that instant will be reflected in how hard it hits you!
  • #36
Just a small caveat that velocity ( nor the derivative in general) is not necessarily changing. Speed may be constant. Please ignore if you're aware of this.
  • #37
Summary:: What is the change actually at some time ##t_0##?
I want to reiterate what was said in post #13. The definition is not about change, it is about the rate of change. In the limit, the rate of change at a point is exact.
Let ##v(t)= 32t##, then ##\frac {dv}{dt} = 32##.
We can get ##v(5.001)## two ways 1) exactly compute is ##v(5.001)=32(5.001) = 160.032##
or 2) estimate it with the derivative;
##v_{approx}(5.001) ≈ v(5) + \frac{dv}{dt} \Delta{t} = 160 + 32*0.001 = 160.032##
It is exact only because we are using a linear function with a constant slope.
  • #38
We define differentiation as the limit of ##\frac{f(x+h)-f(x)}h## as ##h->0##. ... Change at ##t_0## is meaningless in the same way as the slope at a point. How can there be a change at say 5 sec? We have to take two points to talk about change in between them.
We do. As h gets closer and closer to zero the curve more and more resembles a linear curve, i.e. a straight line with a definite slope.
Think about magnifying the curve at x0 billions, trillions, septillions of times. The magnified portion will resemble a straight line with a definite slope. It is this linear slope that defines the derivative at x0.
The differential, dx, which used to be defined as an infinitesimal distance, is now defined as that distance over which the curve becomes linear (or a surface becomes a flat plane).
So there are essentially two points, x0 and x0+h, that define a slope which is considered the derivative at x0.
There are points at which a derivative does not exist. See, for example, the absolute value function:
https://en.wikipedia.org/wiki/File:Absolute_value.svg
The AV function has no derivative at x=0 because there is no interval, however small, around x=0 that would closely approximate a linear curve or straight line. (We could however consider left- and right-sided derivatives.)
So we are, in effect, considering two points, x0 and x0+h, in the definition of the derivative.
There is also a difference between the mathematical and the physical interpretation of the differential. In math, the differential is truly vanishingly small. It is a limit. But in physics, the differential is something that is small enough to be experimentally undetectable and how small depends on the particular experiment.
Again, the key idea is that we can "magnify" any curve (or surface) so that it becomes essentially linear (planar) and thus will have a definite slope (or tangent plane). This slope is the derivative.
  • #39
Not so for just any old curve. A counterexample is the Weierstrass function, a particularly pathological function the is continuous everywhere, but differentiable nowhere (see https://en.wikipedia.org/wiki/Weierstrass_function).
Likes sysprog
  • #40
I find the picture usually helps.
  • #41
So what? That's not the issue nor does it constitute a counterexample to anything I have stated.
The OP asked what I consider to be a legimate question. The status quo in current mathematics is to obscure all hope of intuition with endless "epsilon delta" proofs. Mathematics need not be so visually sterile.
Differentiation implies continuity but continuity does not imply differentiation. The Weirstrauss function demonstrates this but this is also a completely different issue.
The OP wants to know how a "slope," or derivative, can be defined using only a single point, which is the OP's
interpretation. I simply illustrated the fact that two points, in effect, are actually used to define the derivative.
  • #42
You said you could magnify any curve and it will eventually look linear. @Mark44 gave you an example of a curve where you can't do that. How is that not a counterexample?
You don't even need that weird of a function. No matter how much you magnify f(x)=|x| around x=0, it will never look linear.
Likes benorin, WWGD, Mark44 and 1 other person
  • #43
Since the topic is differentiation it should have been clear that I meant any differentiable curve. In fact I even provided my own counterexample with the absolute value function which is not differentiable at a single point. The Weirstrauss function is not differentiable at any point.
Furthermore, in this case, the Weirstrauss function is a bad pedagogical example because it does not combine both differentiablity and non-differentiability in the same curve, as does the absolute value and other functions.
  • #44
By "is not differentiable at a single point" you presumably meant "is non-differentiable at only a single point".
As @Mark44 observed, it's continuous everywhere, and differentiable nowhere. Whether that makes it a good or bad example depends on what it's being presented as an example of. In this instance, the context was as a counterexample to your statement that you only later qualified as meant to be referential only to differentiable curves. Consequently, I disagree with the contention that the fact that the function "does not combine differentiability and non-differentiability in the same curve" makes it "a bad pedagogical example".
  • #45
I mean this in the nicest, most non-condescending way possible: you guys please remember the purpose of this is thread to help the OP, is there some pressing need for a counter example still? I can breakout with my ample Counterexamples in Analysis text by Gelbaum & Olmstead if need be, it's got a cornucopia non-differentiable functions for every occasion, just tell me the specific need?
  • #46
Probably not any additional ones, but the reason for them was to counter an incorrect statement earlier on, that
(Emphasis added by me.)
Likes sysprog
  • #47
@benorin, your reference to Counterexamples in Analysis by Gelbaum & Olmstead is appreciated ##\dots##
Likes benorin
