Problem with values for a bending moment diagram
In summary, the homework statement is to calculate the bending moments for a beam with supports at points 0m and 5m.
PizzaWizza
I have a 5m long simply supported beam, with supports at points 0m and 5m. There's a UDL of 10kNm^-1 from 0m to 4m. It has downward forces acting at 2m (10kN) & 4m (15kN). I need to sketch a bending moment diagram to determine the position & value of the max bending moment. I'm asked to show workings using 1m intervals for bend moment calcs.
Taking moments from one end to determine upward supports.
UDL = 4m x 10kN^-1 = 40kNm^-1 @ 2m (centre of)
Taking moments from Support 1 (R1) = 10x2 + 40x2 + 15x4 = R2 x5
R2 = 160/5 = 32kN. ∴ R1 - 33kN (As the sum of downward forces = 65kN)
I've sketch a shear force diagram that I'm happy with, now to where I'm becoming undone.
Calculating the bending moments for the beam @ 1m intervals
M0 = 0
M1 = 33x1 - (10x0.5x1(UDL)) = 33-5 = 28kN @ 1meter
M2 = 33x2 - (10x1x2(UDL)) - (10x1) = 66-30 = 36kN @ 2meters
M3 = 33x3 - (10x1.5x3(UDL)) - (10x2) = 99-65 = 34kN @ 3meters
M4 = 33x4 - (10x2x4(UDL)) - (10x3) - (15x1) = 132-125 = 7kN @ 4meters
I'm assuming M5 has to be zero. This just doesn't feel right to me. I've got 15kN acting @ 4m and it doesn't seem to be having an effect on the diagram if graphed. I have to be doing something wrong?
Thanks for any help.
You should post you SF diagram.
The BM is the area under the SF curve starting at x = 0. I think you have incorrectly done your integrations of the SF curve for x = 1, 2, 3, and 4 m.
Thanks for the feedback. Here's the Shear force diagram.
So far, so good. And the bending moments?
The bending moments I've highlighted in the original message. They're wrong, I know. I just don't know why?
Perhaps because you didn't use the shear force diagram correctly?
The shear force diagram is constructed, in part, to allow the ready creation of the bending moment diagram.
Thanks. I appreciate it and I think it's sank in now :)
Related to Problem with values for a bending moment diagram
1. What is a bending moment diagram?
A bending moment diagram is a graphical representation of the bending moments at different points along a beam or structure. It is used to visualize the distribution of forces and moments acting on the structure and is an important tool in structural analysis and design.
2. What causes problems with values for a bending moment diagram?
Problems with values for a bending moment diagram can arise from incorrect assumptions or calculations, as well as structural changes or failures. It is important to carefully consider all forces and loads acting on the structure and to use accurate calculations and formulas to avoid errors.
3. How can I determine if the values on my bending moment diagram are accurate?
To ensure the accuracy of values on a bending moment diagram, it is important to double check all calculations and assumptions. You can also use computer software or simulation programs to verify your results. It is also helpful to consult with other engineers or experts in the field for a second opinion.
4. Can a bending moment diagram be used for any type of structure?
Yes, a bending moment diagram can be used for any type of structure, as long as the forces and loads acting on the structure are properly accounted for. This includes beams, columns, trusses, and frames. However, different types of structures may require different methods of analysis and calculation.
5. Are there any limitations to using a bending moment diagram?
While a bending moment diagram is a useful tool for structural analysis and design, it does have limitations. It assumes that the structure is made of a homogeneous material and is subject to only small deformations. It also does not account for dynamic or time-dependent loads, which may require more complex analysis methods. Additionally, it is important to consider other factors such as material strength and stability when using a bending moment diagram for design purposes.
12K
18K
33K
13K
