Problems installing the TMDlib package
  • Thread starter Thread starter Milleniumeye
The discussion revolves around the installation of the TMDlib package (v.2.2.10) and an error encountered when running the TMDlib_Fortran.F example. After following the installation instructions and downloading a PDF set, the user receives an error indicating that a specific file does not exist in the expected directory. It is suggested that the error arises because the program is looking for a file named ccfm-JH-2013-set1.info, which is not found. Recommendations include checking the example Fortran code for necessary edits or command line arguments and consulting the manual for further guidance.
Milleniumeye
TL;DR Summary
The conversation discusses the installation and use of the TMDlib source package from http://tmdlib.hepforge.org/.
I'm trying to install the TMDlib package (v.2.2.10). I followed the instructions from the README file:
./configure --prefix=/home/alexey/Software/TMDLIB --with-lhapdf=/home/alexey/Software/LHAPDF
make
make install
Next, I installed one of the PDF sets:
./TMDlib-getdata ccfm-JH-2013-set1
Everything was going well, but when I run the TMDlib_Fortran.F example I get an error
TMDinfo: file does not exist /home/alexey/Software/TMDLIB/share/tmdlib//.info
return on EXIT_FAILURE
Has anyone encountered a similar error?
Best regards!
Technology news on Phys.org
I'm not surprised that file does not exist, it should be looking for something like ccfm-JH-2013-set1.info in whatever path you have downloaded it into. You probably need to edit something in the example Fortran code, or pass it a command line argument.
Reading the fine manual might be a good idea at this point.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
I am trying to run an .ipynb file and have installed Miniconda as well as created an environment as such -conda create -n <env_name> python=3.7 ipykernel jupyter I am assuming this is successful as I can activate this environment via the anaconda prompt and following command -conda activate <env_name> Then I downloaded and installed VS code and I am trying to edit an .ipynb file. I want to select a kernel, via VS Code but when I press the button on the upper right corner I am greeted...
