Problems on the making of a quantum gravity theory
Instead, the Einstein-Hilbert action involves only a dynamical metric, which defines the gravitational field; it is the solution to Einstein's equation that provides the metric tensor's values everywhere.How well does the Einstein-Hilbert action accomplish this task...? In summary, the Einstein-Hilbert action lacks a clear, fundamental justification, and its validity is in doubt in light of recent advances in theoretical physics.
trees and plants
Hello. What are the problems specifically or mathematically or physically that physicists find difficulty in solving to make a theory of quantum gravity? Thank you.
The problem is the renormalisation trick that works in other Quantum Field Theories does not work in Gravity:
https://quantumfrontiers.com/2013/06/18/we-are-all-wilsonians-now/
But as explained above we look on renormalisation differently these days. We think every theory has some kind of cutoff beyond which it is not necessarily correct in all aspects. These are called effective field theories. For example Quantum Electrodynamics at high energy becomes combined with the theory of weak interactions to become the Electroweak Theory:
https://en.wikipedia.org/wiki/Electroweak_interaction
Since this is an A level thread I would expect the OP to be familiar with all this. Because of this I have changed the level of the thread to B. If the OP thinks they are are at the A level contact a mentor to change it back, but then the answers will be more advanced and they may not be understood.
The specific answer to the question is using the effective field theory approach to quantum gravity they can be combined without any issues:
https://blogs.umass.edu/donoghue/research/quantum-gravity-and-effective-field-theory/
The real issue is, like all the other theories we have, we do not know what lies beyond that cutoff, or even where the cutoff actually is. It is thought to be about the Planck scale, but that is sort of an educated guess. All sorts of things could be going on before that extremely high energy level is reached.
Thanks
Bill
Likes Buzz Bloom, exponent137 and BvU
One big problem is that as quest for unifying QM and GR, is not driven by experimentally accessible unexplained phenomena, but by the fact that we have a patchwork of mathematical descriptions of gravity and particle physics. This keeps some of us awake at night, while some are more pragmtic about this.
So the field is working in darkness without much experimental guidance.
Instead the main guidance is analysing the constructing principles of each model in the pathwork, and to try to extract from what what the deeper principles are that has the potential to embrace the whole domain. Different researchers has different opinions (or educated guesses) on what the "right" constructing principles are, and which that are the fallacious ones. Another guiding principles is which approaches that adds more explanatory power, by for example reducing the number of free parametrs or the number of "ad hoc assumptions" going into the theories. Other approaches are to not think so much philosophical but just to try to look at the "tool space" and see what other possible mathematical solutions there is. All theories are based on assumptions. As it seems even "simplicity" is a relative concept.
/Fredrik
Likes Delta2
QM requires constant time surfaces, which may not exist in curved spacetime?
Fra said:
{snip}
{italics added for emphasis}
Concur. While I lack knowledge to comment on the apparent lack of experimental results, Fra Frederick's conclusion appears rigorous. Simplicity requires comparisons as distinguished from reductionism, if only to examine an emergent system beyond an arrangement of parts. Simplicity implies, even demands, the simplest solutions that work; that fit known facts.
Elegance inherent in simple working solutions tends to verify this conclusion despite the apparent subjective nature of 'elegance' and 'beauty' in mathematics.
It's due to an old conundrum - does gravity really curve space-time or does treating the metric like a gravitational field (Guv) act on all objects to make it appear spacetime is curved. There is no way to tell the difference. It's easier to take the second view when doing quantum gravity.
Thanks
Bill
Likes exponent137
Another take on this is that it comes down to what you think are "observables" in GR, they are not necessarily the same as what you get from observations. This is also one of the debates. Ie. can you just "decide" arbitrarily which "elements" in GR (in some reformulation) where to apply QM formalism? After all, you can not make an elementary "observation" of a global or even a patch of a metric, it is necessarily a compound observation.
A tension is that, on one hand actual "real" observations often requires making an arbitrary choice. But the equivalence class that's remains when compensating for choices are sometimes thought of as are more "real" or observer invariant. (for good reasons). But one can also argue that the equivalence class is an emergent construction and thus may not be fundamental (although in a sense, more robust/real).
/Fredrik
Maybe this link of Isham will help.
https://arxiv.org/pdf/gr-qc/9510063.pdf
It is not only for the advanced level; I think.
General relativity is fundamentally different from any physical theory that has come before it. Pre-general relativistic theories have as part of their very formulation an a priori given metric. For example in the theory's action principle there appears an a priori given metric that is part of the very definition of the theory.
The Einstein-Hilbert action for classical GR, however, has no a priori given background metric that is part of the formulation of the theory. Roughly speaking there is no further container over which the dynamics of spacetime geometry can take place. This is a subtle point.
Now, if you wish the formulation of the quantum theory to also to not depend on any a priori background metric then you can make arguments that such a theory will be manifestly finite. Here is an argument given by Smolin:
“ A background independent operator must always be finite. This is because the regulator scale and the background metric are always introduced together in the regularization procedure. This is necessary, because the scale that the regularization parameter refers to must be described in terms of a background metric or coordinate chart introduced in the construction of the regulated operator. Because of this the dependence of the regulated operator on the cuttoff, or regulator parameter, is related to its dependence on the background metric. When one takes the limit of the regulator parameter going to zero one isolates the non-vanishing terms. If these have any dependence on the regulator parameter (which would be the case if the term is blowing up) then it must also have dependence on the background metric. Conversely, if the terms that are nonvanishing in the limit the regulator is removed have no dependence on the background metric, it must be finite. ”
If you want to quantise GR in a background independent manner then you can't use perturbation theory, for perturbation theory splits the metric into a flat non-dynamical part that serves as a background metric and a part that you allow to be dynamical which you then quantise (using standard techniques).
If you want to quantise GR in a background independent way you have to do a non-perturbative quantisation that does not depend on any a priori given metric. This would appear to be a big ask because you have to quantise Einstein's full field equations which are immensely complicated, and also because all standard quantisation techniques rely heavily on the existence of an a priori background metric, you have to come up with new quantisation techniques. There are serious technical problems to be overcome, not to mention serious conceptual problems that come up in attempting to quantise a fully dynamical theory of spacetime. Perturbation theory renders quantum gravity a standard QFT and so hides the serious conceptual problems that you must at some point tackle.
In loop quantum gravity there has been much progress in addressing the technical problems and also people working in LQG (for example Rovelli) have made much progress in addressing conceptual problems. But it is far from clear whether LQG or something that grows out of it will be the final theory.
Likes BvU
Related to Problems on the making of a quantum gravity theory
1. What is quantum gravity?
Quantum gravity is a theoretical framework that aims to reconcile the theories of general relativity and quantum mechanics. It seeks to explain the behavior of matter and energy at the smallest scales, such as those found in the fabric of spacetime.
2. Why is it difficult to create a quantum gravity theory?
The challenge of creating a quantum gravity theory lies in the fact that the two theories it seeks to unify have fundamentally different principles and equations. General relativity describes the behavior of gravity on a large scale, while quantum mechanics deals with the behavior of particles on a small scale. Combining these two theories poses significant mathematical and conceptual challenges.
3. What are some proposed theories of quantum gravity?
Some of the most well-known theories of quantum gravity include string theory, loop quantum gravity, and causal dynamical triangulation. These theories use different approaches and mathematical frameworks to try to reconcile general relativity and quantum mechanics.
4. How does quantum gravity relate to the search for a theory of everything?
Quantum gravity is often seen as a key component in the search for a theory of everything, which would be a single, unified theory that explains all of the fundamental forces and particles in the universe. Since gravity is one of the four fundamental forces, any theory of everything must also incorporate a theory of quantum gravity.
5. What are some potential applications of a quantum gravity theory?
A successful theory of quantum gravity could have a wide range of applications, including helping us better understand the behavior of matter and energy in extreme conditions, such as inside black holes or during the early moments of the universe. It could also potentially lead to new technologies and advancements in fields such as quantum computing and space travel.
  • Beyond the Standard Models
