Problems when averaging a value
In summary, you have a problem with getting an average when suma2 is declared as real(8). Changing to real(8) gives you more precision in the calculation.
jbenet
Hi,
I am running a fortran 90 program and I have some problems when getting an average. It happens that at some point the value of suma2 is not updated, even when the value of the term s(fixed2(j))/real(nfixed) is not zero. Below is the output of fort.32. The problem dissapears when suma2 is declared as real(8), could anyone please tell me the reason?
Thank you very much
Code:
real :: suma2
10 do i = 1, ncycle
  call   mc_swap_thermo(n1,nsites,s,sorted,beta,lambda,seed,neigh,iacc,fixed1,fixed2,nfixed,sblock,sfixed,switch_thermo)
  do j = 1, nfixed
    suma2 = suma2 + s(fixed2(j))/real(nfixed)
    write(32,*) suma2, s(fixed2(j)), s(fixed2(j))/real(nfixed)
  end do
  steps=steps+1
end do
   262144.000       0.00000000       0.00000000
   262144.000      0.139704779       1.16420649E-02
Technology news on Phys.org
I think the real(8) increases the precision to double ie 64-bit precision whereas the real or real(4) is only 32-bit precision.
Likes jbenet
jbenet said:
Hi,
Thank you very much
real :: suma2
10 do i = 1, ncycle
do j = 1, nfixed
end do
steps=steps+1
end do
What you're encountering is the difference in precision between real (4 bytes) and real(8) (8 bytes). With 4-byte reals, you have only about 7 digits of precision. When you add .0116 to 262144.00, the change is too small to affect the larger number. Changing to 8-byte reals gives you precision out to 12 or 13 places, if I'm remembering correctly.
Likes jbenet
real*8 is the same as double in C, so the machine epsilon is 2−52 ≈ 2.22e-16, giving 15 to 16 decimal places.
Likes jbenet and Mark44
Ok, I understand now. Thank you very much
Related to Problems when averaging a value
1. What is the purpose of averaging a value?
The purpose of averaging a value is to find a single representative number that summarizes a set of data points. This can help to simplify complex data and make it easier to interpret and compare.
2. What are some common problems when averaging a value?
Some common problems when averaging a value include outliers, missing data, and different measurement units. These can skew the average and make it less accurate.
3. How can outliers affect the average value?
Outliers, or extreme values, can significantly impact the average by pulling it towards their direction. This can result in a misleading representation of the data and should be carefully considered when calculating averages.
4. What should be done if there is missing data when calculating an average?
If there is missing data, it is important to decide whether to exclude those data points or to fill in the missing values. Both approaches can affect the accuracy of the average, so it is crucial to consider the implications of each option.
5. How can different measurement units affect the average value?
Different measurement units can distort the average value, especially if they are not converted to a common unit. This can result in an inaccurate representation of the data and should be taken into account when calculating averages.
