Problems with implicit differentiation
In summary, when using implicit differentiation to find the slope of a line in a problem such as y^2 + x^2 = 9, an extra (dy/dx) may appear due to the chain rule. This is because y is being treated as a function of x, rather than a specific function as in the example of y=e^x+x^3. This general approach allows for the slope to be found for any value of y.
giant016
In a problem where I need to use implicit diff. to find the slope of a line such as:
y^2 + x^2 = 9
2y (dy/dx) + 2x = 0
dy/dx = -y/x
Where does the (dy/dx) after the 2y (in the second part) come from? I've already differentiated y^2, x^2, and 9. Why isn't it just 2y + 2x = 0? I've looked all over, and in every problem an extra (dy/dx) or two just seem to pop up out of nowhere. Thanks!
Think of Y as a function in X. Then it's just the chain rule.
For example if y=e^x+x^3
y' = e^x + 3x^2
y^2 + x^2 = 9 is
(e^x+x^3)^2 + x^2 - 9 = 0
when we plug in y
differentiating this we get
2(e^x+x^3)(e^x + 3x^2) + 2x = 0
or 2y*(dy/dx) +2x = 0
when you do implicit differentiation you are doing it for a general y function of x instead of something specific (like as in our case of y=e^x+x^3)
The (dy/dx) after the 2y comes from the chain rule. When you differentiate y^2, you need to use the chain rule because y is a function of x. So the derivative of y^2 is 2y(dy/dx). Similarly, when you differentiate x^2, the derivative is 2x(dx/dx), but since dx/dx is just 1, it is usually not written. In this problem, you are essentially finding the derivative of y^2 + x^2 with respect to x, so you need to use the chain rule for both terms.
It is important to remember that when using implicit differentiation, you are treating y as a function of x, even though it is not explicitly written as y = f(x). So every time you differentiate y, you need to use the chain rule. This can be a source of confusion for some students, but with practice, it will become more natural.
In some problems, the (dy/dx) may not be explicitly written, but it is still present. For example, in the equation y^2 + x^2 = 9, if you were to solve for dy/dx, you would end up with dy/dx = -y/x. The (dy/dx) is implied in this case.
Overall, implicit differentiation can be tricky at first, but with practice and a good understanding of the chain rule, it becomes easier to handle. Just remember to always use the chain rule when differentiating y and keep an eye out for the (dy/dx) terms.
FAQ: Problems with implicit differentiation
What is implicit differentiation?
Implicit differentiation is a mathematical technique used to find the derivative of a function that is not explicitly written in terms of its independent variable. It is commonly used when the derivative of a function cannot be easily found using traditional differentiation methods.
Why is implicit differentiation used?
Implicit differentiation is used when the dependent variable in a function cannot be easily isolated and the traditional differentiation rules cannot be applied. It allows us to find the derivative of a function without explicitly solving for the dependent variable.
What are the challenges of using implicit differentiation?
One of the main challenges of implicit differentiation is that it can be more time-consuming and complex compared to traditional differentiation methods. It also requires a good understanding of algebra and the chain rule.
When should I use implicit differentiation?
Implicit differentiation should be used when the dependent variable in a function cannot be easily isolated and the traditional differentiation rules cannot be applied. This is often the case when dealing with equations involving multiple variables or equations with higher order derivatives.
What are some real-world applications of implicit differentiation?
Implicit differentiation has many real-world applications, such as in economics, physics, and engineering. It is commonly used to find the slope of a curve, optimize functions, and solve differential equations that cannot be solved using traditional methods.
