Problems with Power only using velocity and force
In summary, the interaction between an object moving with a velocity of [4m/s,-1m/s,3m/s] and a force of [-5N,0,+5N] has a power of -5W. This is calculated by taking the scalar product (dot product) of the force and velocity. The negative velocity does not affect the power, as power is not a vector and does not have a direction.
Psip
An object moving with a velocity whose components are [4m/s,-1m/s,3m/s] is acted on by a force whose components are [-5N,0,+5N]. What is the power of the energy transfer involved in this interaction?
Power=F*v
4m/s*-5N= -20W
-1m/s*0=0W
23m/s*5N=15W
(202+152+02)sqrt=Magnitude = 25W which could be the answer but I'm not sure. I just don't know how negative velocity affects power because P=Fv so if F is 5N and v=-3m/s then it would seem like -15W is the answer but I am not sure. I also don't really have experience with 3-component vectors.
It's OK up to here.
Psip said:
(20^2+15^2+0^2)sqrt=Magnitude = 25W
This treats the three amounts you have calculated as vectors, but they are not. Power is not a vector. So you don't square and add to get a magnitude. You just add.
Power is the scalar product (dot product) of force and velocity.
Thank you for your reply, that does make sense that Power isn't applied in a direction. So the answer is -5W
Related to Problems with Power only using velocity and force
What is power?
Power is the rate at which work is done or energy is transferred. It is equal to the product of force and velocity, and is measured in watts (W) or horsepower (hp).
How is power related to velocity and force?
Power is directly proportional to both velocity and force. This means that an increase in either velocity or force will result in an increase in power, while a decrease in either will result in a decrease in power.
What are the limitations of using only velocity and force to calculate power?
Using only velocity and force to calculate power does not take into account other factors that could affect power, such as the direction of the force or the presence of friction. This can result in an inaccurate calculation of power. Additionally, power is not the only factor to consider when evaluating a system, as other factors such as efficiency and work done may also be important.
Can power be negative?
Yes, power can be negative. This occurs when the force and velocity are acting in opposite directions, resulting in power being transferred in the opposite direction. For example, when a car is braking, the power produced by the engine is negative as it is working against the velocity of the car.
How can problems with power using only velocity and force be solved?
In order to solve problems with power using only velocity and force, it is important to consider other factors that may affect power, such as direction of the force and the presence of friction. It is also important to evaluate the system as a whole, rather than just focusing on power, in order to determine the most accurate and comprehensive solution.
