Procedure of preparation of HCl
In summary, the purpose of preparing HCl is to use it as a strong acid in various chemical reactions and processes. Its chemical formula is HCl, which consists of one atom of hydrogen and one atom of chlorine. The basic materials needed for preparation are hydrogen gas and chlorine gas, and the procedure typically involves a reaction vessel and a source of heat. Safety precautions should be taken when preparing HCl due to its corrosive and toxic nature.
Jeanclaud
Knowing that HCl is strong acid we want to prepare HCl solution of pH=4.2.starting from a solution of pH=2.9.Explain briefly the procedure that should be followed to do this operation.
pH=-log(H3O+)
3. The Attempt at a Solution [/B]
I calculated: At beginningC(H3O+)=1.258×10^-3mol/L
at end C(H3O+)= 6.309×10^-5mol/L
and please I want to know is the procedure dillution?
Yes, it is dilution. You need to find out in what ratio to mix your original acid with water.
Related to Procedure of preparation of HCl
1. What is the purpose of preparing HCl?
The main purpose of preparing HCl is to use it as a strong acid in various chemical reactions and processes. It is commonly used in industries for manufacturing different products and in laboratory experiments for its acidic properties.
2. What is the chemical formula for HCl?
The chemical formula for HCl is HCl, which represents one atom of hydrogen and one atom of chlorine bonded together in a molecule.
3. What are the materials needed for preparing HCl?
The basic materials needed for preparing HCl are hydrogen gas and chlorine gas. Other materials such as a reaction vessel, a source of heat, and a condenser may also be required depending on the specific procedure used.
4. What is the procedure for preparing HCl?
The most common procedure for preparing HCl involves the reaction of gaseous hydrogen and chlorine in the presence of a catalyst, such as activated charcoal. The gases are passed through a reaction vessel at high temperatures and then condensed to form liquid HCl.
5. Are there any safety precautions to consider when preparing HCl?
Yes, HCl is a highly corrosive and toxic chemical. It is important to handle it with caution and wear appropriate protective gear, such as goggles, gloves, and a lab coat. It should also be prepared in a well-ventilated area to avoid inhaling the toxic fumes.
