Procedure to express radiation intensity of an LED in watts/cm^2
In summary, The LEDs are providing 20mW of power to the target. The target has a viewing angle of θ of . The luminous intensity of the green LED is 120 mcd. The luminous intensity of the UV LED is 20 mW. The luminous intensity of the target is 120 mcd*20 mW= 2400 lumens.
Abhishek K J
TL;DR Summary
Procedure to calculate radiant intensity of a LED in watts/cm^2 given total radiant power of the LED or luminous intensity of the LED. Note that the target (on which radiation from LED is falling) is placed close to the LED source and is big enough to accommodate circle projected by the light cone from the LED. LED has narrow wavelength band, and assume almost uniform intensity distribution. Viewing angle and other details are accurate.
I am calculating Responsivity of a pn junction photodiode (a.k.a the target) by irradiating radiation from LED sources. For this purpose, i have two LEDs, one UV and another green LED. Note that LEDs are placed close to the target.UV LED : Manufacturer has given total radiant power to be 20mW. How can i calculate radiant intensity in watts/cm^2 ? should i just divide the power of LED by the total area of the target since all radiation from UV LED is reaching the target (since the LED is placed close to the target)?Green LED : Luminous intensity is given in mcd (as"x" mcd). I have converted mcd into lumens then finally to watts as follows :Firstly, i find total solid angle using the expression: Ω (solid angle)= 2(pi)(1-cos(θ)). here, θ is half the apex angle of the light cone. Apex angle is also equal to viewing angle of the LED mentioned in the datasheet.Now, Lumens = Ω*(x) mcd. After this, i use the luminosity efficiency function to convert lumens into watts.Now, given that i have placed the LED near the target, how to find the radiant intensity in watts/cm^2 ? Should i just divide the power by area of the target ? Or, should i divide the power of the LED by the area of the circle projected onto the target by the light cone?
n each case you need to estimate the intensity patern because
UV: the 20mW is distributed across the entire illuminated beam somehow
Green: use the luminous efficiency as you have done (correctly I presume) and then realize that the quoted number is typically the peak value luminous flux (for the beam center)
The radial beam pattern for LEDs is published if you know the type. Make a +/-20% estimate and calculate
Okay. Yes,i have used luminosity efficiency function correctly, i presume !
Can you answer my last doubt, which is, while expressing radiant intensity (in watts/cm^2), should i divide by the area of the target or by the area of the circle projected by the light cone on the target? i am assuming that the circle projected on the target contains 20mW in it, the reason behind the assumption is that, datasheet mentions viewing angle .
Be careful about what sensor and meter you use. The sensor itself has a color response that must be considered in any measurement.
Also, IIRC, most commonly used meters assume that the whole aperature is illuminated.
a lux meter cannot accurately display the intensity of an LED, especially if the LED is monocolored blue or red light, and certainly not when it is a mixed purple light.
https://ledlightinginfo.com/can-a-lux-meter-measure-led-light
(https://www.google.com/search?&q=led+light+meter)
https://bioslighting.com/how-to-measure-light-intensity/architectural-lighting/
(https://www.google.com/search?&q=how+measure+optical+intensity)
Cheers,
Tom
The area of the illuminated circle (approximately). The art of the matter is that the circle is not illuminated uniformly, yet the specified intensity is usually the max (central) value and so you should make an estimate of the "effective" spot size. Your eyeball is a very nonlinear (log) detector, so this can be difficult without data.
An indeed be wary of photometric vs radiometric reporting by the light meter.
Alright. Thank you, i think i got it.
Likes hutchphd
I did this for a living for a while and I had a cheatsheet on the wall to remind me of the names and units of all the various units (and per steradian or per area or per 4pi steradian or photometric or radiometric or IR filtered and sensitivity of eyeball or Si and a different name for each). I think you've got this but I always wanted my cheatsheet..and still do, but now there is Wikipedia!
FAQ: Procedure to express radiation intensity of an LED in watts/cm^2
What is the procedure to express radiation intensity of an LED in watts/cm^2?
The procedure to express radiation intensity of an LED in watts/cm^2 is to first measure the radiant flux of the LED in watts (W). Then, divide the radiant flux by the surface area of the LED in square centimeters (cm^2). This will give you the radiation intensity in watts/cm^2.
Why is it important to express radiation intensity of an LED in watts/cm^2?
Expressing radiation intensity of an LED in watts/cm^2 allows for a standardized measurement of the amount of light emitted by the LED. This is important for comparing the performance of different LEDs and ensuring consistency in lighting applications.
How is the radiant flux of an LED measured?
The radiant flux of an LED can be measured using a radiometer. This device measures the amount of light emitted by the LED and converts it into a numerical value in watts (W).
Can the radiation intensity of an LED vary?
Yes, the radiation intensity of an LED can vary depending on factors such as the type of LED, the current and voltage applied, and the temperature of the LED. It is important to measure the radiation intensity under standardized conditions for accurate comparison.
Is there a maximum radiation intensity for an LED?
Yes, there is a maximum radiation intensity for an LED. This is determined by the design and capabilities of the LED and can vary between different types and manufacturers. It is important to not exceed the maximum radiation intensity to avoid damaging the LED.
12K
14K
