Procedure to find Cauchy Integral
In summary, when using Cauchy's integral formula to find the value of a function that is not analytic at a certain point, one method is to use Partial Fraction to break up the rational functions. It is not necessary to take out the numerator before evaluating the residue.
DrMath
28
I have a question - just to check when we know the whole function is not analytic at some point of z. We can use cauchy integral formula of 2*pi*j*f(a) to find the answer.
In between; one of such method is to use Partial Fraction to break up the rational functions.
So do we have to take out the numerator (which is analytic before doing the Integral?).
It's very hard to work out from what you say what your question is, I'm afraid!. If you are talking about using the residue theorem to evaluate a contour integral of a function that is basically a fraction with a pole at some point (within the contour), then the answer is that you don't need to take out the denominator of the fraction before evaluating the answer as its effect will just be included in the evaluation of the residue.
FAQ: Procedure to find Cauchy Integral
What is a Cauchy integral?
A Cauchy integral is a mathematical concept used in complex analysis to calculate the value of a complex function over a closed curve. It is named after the French mathematician Augustin-Louis Cauchy.
How do you find a Cauchy integral?
To find a Cauchy integral, you must first parameterize the closed curve and then integrate the complex function along this curve using the Cauchy integral formula. This formula involves a contour integral and the Cauchy-Goursat theorem.
What is the Cauchy integral formula?
The Cauchy integral formula is used to calculate the value of a complex function at a point inside a closed curve. It states that the value of the function at the point is equal to the sum of the function's values at all points inside the curve, divided by the distance from the point to the curve.
What is the Cauchy-Goursat theorem?
The Cauchy-Goursat theorem is a fundamental theorem in complex analysis that states that if a function is analytic (i.e. differentiable) at all points inside a closed curve, then the Cauchy integral formula holds for that curve. This theorem is used to prove the existence and uniqueness of Cauchy integrals.
What are some real-world applications of Cauchy integrals?
Cauchy integrals have many applications in physics and engineering, particularly in the fields of fluid dynamics and electromagnetism. They are also used in the study of conformal mappings and the solution of differential equations. Additionally, they have applications in finance and economics, such as in the calculation of option prices in financial markets.
