Product of two Polynomials in a UFD
In summary, by using the properties of UFDs and fields of fractions, we can show that every polynomial in R[x] can be factored into a product of two polynomials in R[x] with the appropriate choice of c.
oblixps
38
Let R be a UFD and K be its field of fractions. Let f(x) be in R[x] and f(x) = a(x)b(x) where a(x), b(x) are in K[x]. Show that there exists a c in K such that c*a(x) and c-1*b(x) are both in R[x] and such that f(x) = (c*a(x))(c-1*b(x)) in R[x].
I have been stuck on this for a while now as I am having trouble coming up with what possible c to use. Since c*a(x) must be in R[x], the "numerator" of c must contain the lcm of the denominators of a(x) (i will denote as m) so that multiplying c and a(x) will cancel out all the denominators. Similarly, since c-1*b(x) is in R[x] as well, i need the numerator of c-1 to contain the lcm of the denominators of b(x) (i denote as n). In other words, i need the denominator of c to contain the lcm of the denominators of b(x). So far i have that c = m/n.
This is where i start to have trouble. Looking at c*a(x), after canceling out the denominators of a(x) i still have the factor of n on the bottom and there is no reason to believe that n divides each of the numerators of a(x). So I "divide out" as much as possible and then i am left with n* on the bottom. i can't do anything else so i just shove a factor of n* to compensate on the numerator of c so i now have c = m(n*)/n. So multiplying by the new c will make c*a(x) be in R[x].
Now looking at c-1 = n/(m)(n*) we have that c-1*b(x) the n cancels out so we are left with (m)(n*) on the bottom. Just like before, there is no reason to believe that (m)(n*) can divide each of the numerators of b(x) so i have to add another factor to the numerator of c-1 to compensate for that.but then when i now multiply c*a(x) i may need to add a new compensating factor and so on. it is not clear to me that this process will end.
is this the best way to go about this problem? my argument feels awkward and I would appreciate it if someone could give me some hints on how to better approach this.
One possible way to approach this problem is to use the fact that R is a UFD (unique factorization domain) to factor the polynomials a(x) and b(x) into irreducible factors in R[x]. Then, you can use the fact that K is the field of fractions of R to write each of these irreducible factors as a quotient of elements in K[x]. Finally, you can use the fact that R is a UFD to show that these quotients can be written as a product of elements in R[x]. This will give you a way to write f(x) as the product of two polynomials in R[x], one of which is a multiple of a(x) and the other a multiple of b(x). You can then choose c to be the common factor between these two polynomials, which will guarantee that c*a(x) and c-1*b(x) are both in R[x] and that their product is equal to f(x).
FAQ: Product of two Polynomials in a UFD
What is a UFD?
A UFD, or unique factorization domain, is a type of mathematical ring in which every non-zero non-unit element can be uniquely expressed as a product of irreducible elements. In other words, every element in a UFD can be broken down into a unique combination of prime factors. Examples of UFDs include the integers and polynomials with coefficients in a field.
How do you find the product of two polynomials in a UFD?
To find the product of two polynomials in a UFD, you can use the distributive property and multiply each term in the first polynomial by each term in the second polynomial. Then, combine like terms and factor the resulting polynomial if possible. It is important to note that the product may not always be in the same ring as the original polynomials, so you may need to factor further to express it in terms of irreducible elements.
Can a product of two polynomials in a UFD be factored further?
Yes, it is possible for a product of two polynomials in a UFD to be factored further. This is because the product may not always be in the same ring as the original polynomials, so it may be necessary to factor further to express it in terms of irreducible elements.
Are there any special properties of products of two polynomials in a UFD?
One special property of products of two polynomials in a UFD is that if the original polynomials are relatively prime (meaning they have no common factors), then their product will also be relatively prime. This can be useful in simplifying expressions and solving equations.
Can you give an example of finding the product of two polynomials in a UFD?
Sure, let's find the product of (x+2)(x-3) in the UFD of polynomials with coefficients in the field of real numbers. Using the distributive property, we get x^2 - 3x + 2x - 6. Combining like terms, we get x^2 - x - 6. This polynomial cannot be factored any further, so it is the product of (x+2) and (x-3) in the UFD of polynomials with coefficients in the field of real numbers.
