Production of Z boson - Cross Section
In summary, we are asked to calculate the ratio R for energy around 10 GeV and determine the beam energy at which the contribution to cross section from gamma is equal to that of the Z0 exchange, assuming equal vertex factors for EM and weak interaction. We find that R is equal to 11/3 and the beam energy should be approximately 0.46 times the mass of the W boson.
unscientific
1,734
Calculate the ratio ##R = \frac{\sigma_{had}}{\sigma_{\mu+\mu-}}## for energy around ##10~GeV##.
At sufficiently high energies, the ##e^+e^- \rightarrow \mu^+ \mu^-## reaction can proceed via the ##Z^0## boson. Assuming vertex factors for EM and weak interaction are the same, at what beam energy (below ##M_Z##) would the contribution to cross section from ##\gamma## be the same as the contribution from the ##Z^0## exchange?
Since at around ##10~GeV##, production of u,d,s,c quarks are possible, ##R = 3 \times \left[ (\frac{1}{3})^2 + (\frac{2}{3})^2 + (\frac{1}{3})^2 + (\frac{2}{3})^2 + (\frac{1}{3})^2 \right] = \frac{11}{3}##.
Since we can assume the vertex factor for EM and weak interaction to be the same, thus the cross-section for (##e+e \rightarrow \mu^+\mu^- ##) is the same for weak and EM. We have just calculated ##R = \frac{11}{3}##.
Since cross-section grows as ##\sigma \sim E_{cm}^2##, total contribution from EM processes is ##\left(1 + \frac{11}{3}\right) E^2##. Contribution from ##Z^0## process is simply ##M_w^2##.
Does this mean that ##E = \sqrt{\frac{3}{14}}m_w = 0.46m_W##?
bump
Related to Production of Z boson - Cross Section
1. What is the significance of the Z boson cross section in particle physics?
The Z boson cross section is a measurement of the probability of producing a Z boson in particle collisions. It is an important quantity in particle physics as it can provide insights into the fundamental interactions between particles and the structure of matter.
2. How is the Z boson cross section calculated?
The Z boson cross section is calculated using theoretical models and experimental data. Theoretical models use the principles of quantum field theory to predict the likelihood of Z boson production in different collision scenarios. These predictions are then compared to experimental data from particle accelerators to verify their accuracy.
3. What factors can affect the Z boson cross section?
The Z boson cross section can be influenced by a variety of factors, such as the center-of-mass energy of the particle collision, the type of particles involved in the collision, and the presence of other particles or interactions that can interfere with Z boson production.
4. How does the Z boson cross section relate to the Higgs boson?
The Z boson cross section is related to the Higgs boson through the Higgs mechanism, which explains how particles acquire mass. The Z boson and the Higgs boson are both carriers of the weak nuclear force, and the Z boson cross section can provide valuable information about the properties of the Higgs boson.
5. What are some current research areas related to the Z boson cross section?
Current research on the Z boson cross section includes studying its behavior at high energies, testing the predictions of the Standard Model, and searching for new particles or phenomena that may be involved in Z boson production. It is also being used in precision measurements and studies of the fundamental forces of nature.
