Prof. Shankar's (Phy I) Constant Motion Exercise 3 Question
In summary, the conversation was about solving a physics problem involving two moving objects, Romeo and Juliet. The problem was taken from a textbook and involved finding when and where the two objects would cross paths. The conversation also included a discussion about different approaches to solving the problem and some confusion about the algebra involved. In the end, the expert helped clarify the use of the quadratic equation and how it relates to the time function in the problem.
Lucas_30
Hello everyone, this is my first post, so go easy on me! Thank you to those who are able to help.
1. Homework Statement
The problem is taken from Professor Shankar's Fundamentals of Physics exercises (Problem 3).
Romeo is at x = 0 m at t = 0 s when he sees Juliet at x = 6 m
Romeo begins to run towards her at v = 5 m/s. Juliet, in turn, begins to accelerate towards him at a = −2 m/s 2
When and where will they cross?
My personal questions relate to:
1. My approach to the question as opposed to the given solution
2. Some of the algebra in the solution
Working from a position function of x(t) = 1/2at^2 + vot + xo (where a = constant acceleration; vo = initial velocity; xo = initial position)
I took known variables and formed:
x(romeo) = vot + xo (because we know Romeo's initial velocity (5m/s) and his initial position (0 m))
x(juliet) = 1/2at^2 + vot (because we know Juliet's acceleration (-2 m/s^2) and initial position (6m))
Prof. Shankar equates x(romero) to simply vt, as the position would be 0 at t = 0.
Would my way of forming x(romeo) and x(juliet) be correct?
Romeo and Juliet should cross when x(romeo) = x(juliet)
Giving according to my more verbose variables:
vot(r) + xo(r) = xo(j) + 1/2at^2(j)
To solve we would equate one side to 0 and "move across" the required variables, to get for example:
0 = 1/2at^2(j) - vot(r) + xo(j)
Does it matter which way the variables get "moved across"?
Solving 0 = 1/2at^2(j) - vot(r) + xo(j) with the given variables I get a result of:
-3.38600... (-3.0 s rounded to the nearest integer)
0.88600... (1.0 s rounded to the nearest integer)
Prof. Shankar's solutions state: 1 second exactly. Would my above solution be incorrect?
Here is his reasoning:
Would I be correct in saying that he has amended the quadratic equation to better fit the time function t = v2 - v1 / a?
Finally! I don't quite get the algebra behind v/a (1 +- ... ) Would someone be able to help me understand how he derived this from the initial equation?
I hope I've been clear. Thanks again to anyone that can help!
-- Lucas
If I understand correctly what no mean, no it makes no difference on which side you move all the variables.
Solving how?
What do you mean when you say that he "amended the quadratic equation"?
Starting from the quadratic equation, you have
\begin{align*}
t &= \frac{v \pm \sqrt{v^2 - 2 a x_0}}{a} \\
&= \frac{v \pm \sqrt{v^2 - \frac{2 a x_0 v^2}{v^2}}}{a} \\
&= \frac{v \pm \sqrt{v^2\left( 1 - \frac{2 a x_0}{v^2} \right)}}{a} \\
&= \frac{v \pm v \sqrt{1 - \frac{2 a x_0}{v^2}}}{a} \\
&= \frac{v}{a} \left( 1 \pm \sqrt{1 - \frac{2 a x_0}{v^2}} \right)
\end{align*}
Hi DrClaude,
I "solved" it using the quadratic equation:
https://www.symbolab.com/solver/equation-calculator/\frac{ 5 - \sqrt{5^{2} - \left(4\right)\left(-2\right)\left(6\right)}}{2 \left(-2\right)}
https://www.symbolab.com/solver/equation-calculator/\frac{ 5 + \sqrt{5^{2} - \left(4\right)\left(-2\right)\left(6\right)}}{2 \left(-2\right)}
Not sure if this approach is at all correct given the difference in answer?
In terms of the quadratic, I had come across x = -b +- sqrt(b^2 - 4ac) / 2a but thought that by cancelling out the 2 and reducing the 4 to 2, it would help mirror the time function better and perhaps help with the working out of the problem. Wanted to see if this was the right way of thinking about things.
For the final question, I can see that v^2 / v^2 is added (which is essentially 1) ...but I lose it at that point! I'll try and think a little more on the logic, but could you perhaps help me understand why this is done in the first place? What's the motivation? Why not stick with the previous equation?
Thank you,
-- Lucas
Lucas_30 said:
In terms of the quadratic, I had come across https://wikimedia.org/api/rest_v1/media/math/render/svg/2a9804ca8ce019507e3199ca8fced800fb5b7d7c but thought that by cancelling out the 2 and reducing the 4 to 2, it would help mirror the time function better and perhaps help with the working out of the problem. Wanted to see if this was the right way of thinking about things.
I don't understand what you mean.
This trick of multiplying by "1" is often used. Better get used to it. And I gave you all the steps from that point on.
It's the same equation. Where to stop modifying an equation is often up to one's taste.
Hi DrClaude,
There was a problem with the image I used - I have updated the text so it should make sense now.
Yes, you're right in that they are equivalent, but I wanted to know why the latter suited the problem better than the first. I suppose in terms of problem solving I wanted to understand that step as I didn't think of this and wanted to understand things a little better.
When I use the following: https://www.symbolab.com/solver/equ...ft(-2\right)\left(6\right)}}{\left(-2\right)} I get the answer Prof. Shankar also gets. It is slightly off to https://www.symbolab.com/solver/equ...ft(6\right)}}{\left(2\right) \left(-2\right)} which leads me to believe that as you said before the method was correct? From what I can see, the a, b, c (a, vot(r), xot(j)) are correct?
Thanks again,
-- Lucas
##a \neq a## :wink:
Meaning that the coefficient ##a## is not the same as the acceleration ##a##.
Hi DrClaude,
Oh, yes! I did mix this up. 1/2(-2)t^2... so the coefficient should be 1/2(-2).
https://www.symbolab.com/solver/equ...eft(6\right)}}{\left(2\right)\left(-1\right)}
I think this is correct now - so the method looked to be correct. Thank you for your help here.
Might you be able help me see why Prof. Shankar used the second equation for the solution of the problem instead of the simple quadratic? There must be a reason for this beyond his preference for tasty equations?
It makes it more obvious which branch of the square root (+ or -) to keep, even before calculating the numerical values.
Right! Thanks again.
Related to Prof. Shankar's (Phy I) Constant Motion Exercise 3 Question
1. What is the purpose of Prof. Shankar's Constant Motion Exercise 3?
The purpose of this exercise is to help students understand the concept of constant motion and how to calculate displacement and velocity using equations of motion.
2. How do you solve the problems in Prof. Shankar's Constant Motion Exercise 3?
To solve the problems in this exercise, you will need to use the equations of motion (displacement = initial velocity x time + 1/2 x acceleration x time^2 and final velocity = initial velocity + acceleration x time) and substitute the given values into the equations. Then, solve for the unknown variable.
3. What is the importance of understanding constant motion in physics?
Understanding constant motion is crucial in physics as it is the basis for understanding more complex concepts such as acceleration, forces, and energy. It also helps in predicting the behavior of objects in motion and solving practical problems in various fields such as engineering and astronomy.
4. Are there any tips for solving Prof. Shankar's Constant Motion Exercise 3 more efficiently?
One tip is to carefully read and understand the given information and pay attention to the units of measurement. It is also helpful to draw a diagram to visualize the motion and label the known values. Additionally, checking your calculations and units at each step can help you catch any mistakes.
5. Can Prof. Shankar's Constant Motion Exercise 3 be solved using different methods?
Yes, there are multiple ways to solve these types of problems. Some students may prefer to use the graphical method, where they plot the motion on a graph and use the slope to determine the velocity and area under the curve to determine the displacement. Others may use the algebraic method, as mentioned in question 2. It is important to understand both methods to have a well-rounded understanding of constant motion.
