MHB Program to calculate the sum of polynomials
A polynomial can be represented as a dictionary with powers as keys and coefficients as values, such as $x^{12}+4x^{5}-7x^{2}-1$ represented as {0: -1, 2: -7, 5: 4, 12: 1}. A Python function is needed to sum two polynomials in this format. The initial implementation only works for polynomials with the same powers, prompting a discussion on how to handle the general case.To improve the function, it's suggested to iterate over the union of the keys from both polynomial dictionaries. This allows for the inclusion of all powers present in either polynomial. Instead of checking each key's existence with multiple if statements, the use of `get(key, 0)` simplifies the process by returning the coefficient or zero if the key is absent. This approach streamlines the addition of coefficients for each power, ensuring that all terms are accounted for in the final result.
mathmari
MHB
Hey! 😊
A polynomial can be represented by a dictionary by setting the powers as keys and the coefficients as values. For example $x^12+4x^5-7x^2-1$ can be represented by the dictionary as $\{0 : -1, 2 : -7, 5 : 4, 12 : 1\}$. Write a function in Python that has as arguments two polynomials in dictionary representation and returns the dictionary that represent the sum of the polynomials.
I wrote the following program :
Code:
def add_poly(P1, p2) :
  p3 = {}
  for key in p1:
      if key in p2:
          sum_pol = p1[key]+p2[key]
          p3[key] = sum_pol
  return p3
p1 = {0:-1, 2:-7, 5:4, 12:1}
p2 = {0:2, 2:5, 5:2, 12:3}
print(add_poly(p1,p2))
But this works only if the given polynomials have the same powers, right?
What can we change to consider the general case?
I thought to do something like :
Code:
def add_poly(p1, p2) :
    pol = {}
    key = 0
    x = True
    while x == True :
        if key in p1 and key in p2:
            pol['key'] = sum_pol
        elif key in p1 :
            sum_pol = p1[key]
        elif key in p2 :
            sum_pol = p2[key]
        elif key > len(p1) and key > len(p2) :
            x = False
        else :
            pass
        key += 1
    return pol
p2 = {0:2, 2:5, 3:2, 12:3}
But this doesn't work correctly.
:unsure:
Technology news on Phys.org
Hey mathmari!
I can do:
Code:
python
>>> len({0:-1, 2:-7, 5:4, 12:1})
But 4 is not the highest power is it? (Worried)
Klaas van Aarsen said:
I can do:
Code:
python
So is the part
Code:
            x = False
wrong? :unsure:
mathmari said:
So is the part
elif key > len(p1) and key > len(p2) : x = False
wrong?
Indeed. Instead we need to check if the key is greater than the greatest key in both p1 and p2. 🤔
We can use `max(p1)` to find the highest power in `p1`. 🤔
But basically we want to iterate over the set that both polynomials have in common.
We can construct it with `set().union(p1.keys(), p2.keys())`.
Then we can do `for power in set().union(p1.keys(), p2.keys()): ...`. 🤔
Additionally, we can do `p1.get(key, 0)` to get the power if there is one, or 0 otherwise.
Then we don't have to use if statements, but we can just do `p1.get(key, 0) + p2.get(key, 0)`. 🤔
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
