guv
- 123
- 22
- TL;DR Summary
- projected linear separation between companion stars
A quasar with a bolometric flux of approximately 10−12 erg s−1 cm−2 is observed at
a redshift of 1.5, i.e. its comoving radial distance is about 4.4 Gpc.
Assume that the quasar in the previous question is observed to have a
companion galaxy which is 5 arcseconds apart. What is the projected linear separation of the
companion galaxy from the quasar?
The answer key given divides the comoving distance multiplied by angle by (1 + z), z = 1.5 such that
##d = \frac{4.4 Gpc * 5"}{1 + 1.5}##
This answer doesn't make sense because the 5" should stay as a constant as both the distance between the companion and the distance from companion to the Earth should grow at the same rate (Hubble's law). Therefore the correct answer I believe should just be ##5.5 Gpc * 5"## Can anyone more knowledgeable explain if the above reasoning is correct and which solution is correct (even if the question may be silly)?
Thanks,
Thanks,
