Projectile and gravitation problem
In summary, the body will reach a maximum height of 6690.36km if the gravitational force is not considered as constant. If g is a constant, the body will only reach 51.02km.
fluidistic
265
A body is fired vertically from the ground of the Earth with a velocity [tex]v_0=1km/s[/tex]. If the gravitational force is not considered as constant and supposing that the Earth is a sphere of radius [tex]6371km[/tex],
a)Find the maximum height reached by the body.
b)Compare the previous result with the same experience if g is a constant. (That is [tex]9.8 m/s^2[/tex].)
[tex]r_{max}=\frac{1}{\frac{1}{r_0}-\frac{v_0^2}{2GM_E}}[/tex]
I found the formula above in my class notes. If I understand it well, it gives "[tex]r_{max}[/tex]", which I interpret as the distance of a body from the center of the Earth. [tex]r_0[/tex] is the radius of the Earth and [tex]M_E[/tex] is the mass of the Earth.
I don't know how to find this formula so I think I will have to learn it by heart (sadly...). If you know how to reach to it, please let me know.
Now using the formula, I found that the projectile will reach [tex]6690.36km[/tex]! Oh wait... this is the height from the center of the Earth, not the ground as I thought... So it's probably right then.
Because for the b) I get that it reach only [tex]51.020km[/tex], but it is from the ground of the Earth. Now that I think it makes about [tex]319 km[/tex] (if g is not a constant), I think it's too much, isn't it?
You are right, forget the formula. It's too specific to a particular problem. The concept you want is that the sum of the gravitational potential energy (PE) and kinetic energy (KE) is a constant. If you consider the gravitation force to be constant PE=mgr. If you use Newton PE=-G*M*m/r. 319km does seem like a bit much. I agree with your 51.02km for the constant g and g doesn't vary so much near the Earth.
Thank you very much. I'll try it tomorrow, if I have any problem I'll ask for further help, but I think all will be all right.
FAQ: Projectile and gravitation problem
What is a projectile?
A projectile is any object that is thrown, launched, or propelled through the air and is subject to the force of gravity.
What are the key factors that affect the trajectory of a projectile?
The key factors that affect the trajectory of a projectile are the initial velocity, angle of launch, and the force of gravity.
How do you calculate the range of a projectile?
To calculate the range of a projectile, you can use the equation R = (V^2 * sin(2θ)) / g, where R is the range, V is the initial velocity, θ is the angle of launch, and g is the acceleration due to gravity.
How does air resistance affect the motion of a projectile?
Air resistance, also known as drag, can affect the motion of a projectile by slowing it down and changing its trajectory. This is especially noticeable for objects with a large surface area, such as a feather or a parachute.
What is the difference between projectile motion and freefall?
Projectile motion refers to the curved path of an object that is launched into the air and is subject to the force of gravity. Freefall, on the other hand, is the motion of an object that is only affected by the force of gravity and is not propelled by any external force.
