MHB Projectile Fired: Find Time of Flight at Max Height
  • Thread starter Thread starter markosheehan
    Projectile
The discussion focuses on deriving the relationship between the angles of inclination and the projectile's motion along an inclined plane. The time of flight is calculated as 2u sin(b) / g cos(a), with the coordinate system aligned to the plane. Key equations for the particle's motion are established, including the expressions for velocity and position in both x and y directions. The maximum height condition leads to the equation linking the range and height, ultimately simplifying to show that tan(a) tan(b) equals 2/7. This relationship is crucial for understanding projectile motion on an inclined plane.
markosheehan
a plane is inclined at an angle a to the horizontal . a particle up the plane with speed u at an angle b to the plane . when the particle is at its max perpendicular height above the plane it is 3/5 of the range up the plane. show tana*tanb=2/7
so far I have found the time of flight which is 2usinb/gcosa
Mathematics news on Phys.org
I would orient my coordinate axes such that the $x$-axis coincides with the plane, and the origin coincides with the initial position of the particle and so we have:
$$a_x=-g\sin(a)$$
$$a_y=-g\cos(a)$$
And so:
$$v_x=-g\sin(a)t+u\cos(b)$$
$$v_y=-g\cos(a)t+u\sin(b)$$
And:
$$x=-\frac{g\sin(a)}{2}t^2+u\cos(b)t$$
$$y=-\frac{g\cos(a)}{2}t^2+u\sin(b)t$$
When the particle has reached its range up the plane, we have $y=0$ and $t>0$ giving us:
$$t=\frac{2u\sin(b)}{g\cos(a)}$$
And so the range $R$ of the particle is:
$$R=\left(\frac{2u^2\sin(b)}{g\cos(a)}\right)\left(\cos(b)-\tan(a)\sin(b)\right)$$
When the particle has reached its maximum height, we find from $v_y=0$:
$$t=\frac{u\sin(b)}{g\cos(a)}$$
We are told that we must have:
$$x\left(\frac{u\sin(b)}{g\cos(a)}\right)=\frac{3}{5}R$$
$$-\frac{g\sin(a)}{2}\left(\frac{u\sin(b)}{g\cos(a)}\right)^2+u\cos(b)\left(\frac{u\sin(b)}{g\cos(a)}\right)=\frac{3}{5}\left(\frac{2u^2\sin(b)}{g\cos(a)}\right)\left(\cos(b)-\tan(a)\sin(b)\right)$$
This simplifies to:
$$2\cos(b)-\tan(a)\sin(b)=\frac{12}{5}\left(\cos(b)-\tan(a)\sin(b)\right)$$
Divide through by $\cos(b)$:
$$2-\tan(a)\tan(b)=\frac{12}{5}\left(1-\tan(a)\tan(b)\right)$$
And this reduces to:
$$\tan(a)\tan(b)=\frac{2}{7}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
