Projectile fired from earth. Conservation of energy
In summary, the problem involves a projectile being shot away from Earth's surface, neglecting Earth's rotation. The question asks for the radial distance reached by the projectile in terms of Earth's radius, given different initial conditions. The relevant equations are the escape velocity formula and the kinetic energy formula, and the unknown variable is the radial distance. Part a) and b) have incorrect equations, but can be corrected by moving the 0.5 term to the RHS. Part c) involves finding the minimum initial mechanical energy required for the projectile to escape Earth.
auk411
57
A projectile is shot directly away from Earth's surface. Neglect the rotation of Earth.
What multiple of Earth's radius R_e gives the radial distance a projectile reaches if its (a) initial speed is .5 the escape speed from earth, (b) its initial kinetic energy is .5 of the kinetic energy required to escape Earth? (c) What is the least initial mechanical energy required at launch if the projectile is to escape Earth?
v =[tex].5\sqrt{2GM/R}[/tex]
Total mechanical energy = 1/2 mv^2 - GMm/R =?
I know that I'm going to need to plug in the escape velocity for v^2. However, that is all I know.
(As for b and c, I don't even know what the relevant equations are. )
I'm not sure why it states mechanical energy in part of the problem but I'm assuming this is kinetic energy.
[tex] K = \frac{1}{2} mv^2 [/tex]
[tex] v = \sqrt{\frac{2GM}{R}}[/tex]
a) [tex] v = 0.5\sqrt{\frac{2GM}{R}}[/tex] Solve for R
b) [tex] \frac{1}{2}mv^2 = \frac{1}{2}\frac{GMm}{R}[/tex] Solve for R
c) Start with your given formula for v (without the 0.5 that you added) and get to [tex] \frac{1}{2}mv^2 [/tex] on the LHS
So does anyone know how to answer this cause the person before doesn't know how to answer it.
For one thing, part a is just wrong. That is not true equation.
... Unless I'm just totally confused.
You're correct that part a) is wrong. I should have had the 0.5 on the RHS of the equation. And the same for part b). I'll edit my original post to reflect this.
I would respond by providing a detailed explanation and solution to the problem. Here is my response:
First, we need to consider the conservation of energy in this scenario. The total mechanical energy of the projectile at any point during its trajectory is equal to the sum of its kinetic and potential energies. We can express this as:
Total mechanical energy = Kinetic energy + Potential energy
Now, let's look at the three parts of the question separately:
(a) If the initial speed of the projectile is 0.5 times the escape speed from Earth, we can calculate the radial distance it will reach by using the equation for escape velocity:
v = √(2GM/R)
Where v is the escape velocity, G is the gravitational constant, M is the mass of Earth, and R is the radius of Earth.
Substituting 0.5v for v in the equation, we get:
0.5v = √(2GM/R)
Squaring both sides, we get:
0.25v^2 = 2GM/R
Rearranging the equation, we get:
R = 8GM/0.25v^2
Now, we know that the radius of Earth is R_e, so we can express the radial distance reached by the projectile as a multiple of Earth's radius:
R/R_e = 8GM/0.25v^2R_e
Simplifying the equation, we get:
R/R_e = 32v^2/0.5v^2R_e
Therefore, the radial distance reached by the projectile is 32 times Earth's radius.
(b) For the second part of the question, we need to calculate the initial kinetic energy of the projectile and compare it to the kinetic energy required for escape. The kinetic energy of the projectile is given by:
Kinetic energy = 1/2 mv^2
Substituting 0.5v for v, we get:
Kinetic energy = 1/2 m(0.5v)^2 = 0.125mv^2
Now, the kinetic energy required for escape is equal to the total mechanical energy at escape, which we can calculate using the formula we derived earlier:
Total mechanical energy = 1/2 m(0.
FAQ: Projectile fired from earth. Conservation of energy
1. What is a projectile fired from earth?
A projectile fired from earth refers to an object that is launched into the air from the surface of the earth. This can include objects like bullets, missiles, or even sports equipment like baseballs or javelins.
2. What is conservation of energy?
Conservation of energy is a fundamental law of physics which states that energy cannot be created or destroyed, but only transformed from one form to another. This means that the total amount of energy in a system remains constant.
3. How does conservation of energy apply to a projectile fired from earth?
When a projectile is fired from earth, it initially has a certain amount of kinetic energy, or energy of motion. As it travels through the air, it may also have potential energy due to its position relative to the ground. According to the law of conservation of energy, the total energy of the projectile will remain constant throughout its flight, even as it transforms between kinetic and potential energy.
4. What factors affect the conservation of energy for a projectile fired from earth?
The factors that affect the conservation of energy for a projectile fired from earth include its initial velocity, mass, and the presence of any external forces like air resistance or gravity. These factors can impact the transformation of energy between kinetic and potential forms, but the total energy of the projectile will remain constant.
5. Can the conservation of energy principle be violated for a projectile fired from earth?
No, the conservation of energy principle is a fundamental law of physics and cannot be violated. Any apparent violations are due to incomplete understanding or measurement errors. In the case of a projectile fired from earth, the total energy of the system will always remain constant, in accordance with the law of conservation of energy.
