Projectile Intercept Math & Trigonometry
The discussion focuses on setting up equations for intercepting a projectile in a 3D scenario for a video game. The user seeks guidance on calculating the launch parameters needed to hit a target projectile launched at a specific angle and speed, with a delay in the interceptor's launch. Key advice includes equating the positions of both projectiles as functions of time to derive the necessary launch angles and speeds. It is emphasized that a general solution should be developed, allowing for variable parameters rather than fixed values. The conversation highlights the importance of abstract thinking in game design to accommodate changing conditions.
VexCarido
Looking for some guidance on how to set up the equations for a projectile intercept given that you have perfect information about the target velocity, size and weather conditions in a 3D scenario, it's for an amateur videogame that I'm developing in my spare time
For simplicity sake let's assume there's no wind force and that target object is launched from coordinate (5,100,0) at a 55 degree angle along the x-axis, with initial velocity of 40 m/s - we have to launch to intercept the projectile with a delay of 2 second after the initial object is launched. Time of Flight for the object is 6.68 seconds. and we're launching from the origin coordinate (0,0,0)
Our initial projectile launch velocity range is 60 to 120 m/s and with a solution we should end up with a list of possible combinations of angles, and projectile speeds that would successfully intercept the target.
I know how to calculate the trajectory, as well as the horizontal/vertical range & time of flight for both objects I don't think this should be more difficult than rearranging a few components of the equations of motion, but I am at a loss as to how I should go about it exactly. Is there a swift and easy & efficient way to do this?
I don't think there is. You are not answering a homework problem with specific input parameters. You need a general solution given the ever-changing parameters that depend on the user is doing. You are probably looking for expressions for the projection angles (##\theta,~\phi##) of the interceptor given that its speed is fixed at ##v_0.## So you need to write some equations for the position of the enemy projectile and the interceptor as functions of time, take the difference (note that the acceleration term drops out), and see what must be true for that difference to be zero.
Figuring out the position of the target as a function of time is not the hard part, this can be done very simply by rearranging the 2D equation for the trajectory of a projectile to account for the added z axis.
Or by implementing the Euler method to approximate the trajectory instead.
It's what I do after this that I need help with. To simplify the problem even further let's fix our own initial launch velocity to 80 m/s.
VexCarido said:
Summary:: Need help to understand the math of projectile intercept for videogame
I think you will need to equate the coordinates of both the projectiles.
Equate the x(t) of 1st and second particle. And do the same with y(t). Put in the value of t.
You will get the angle of projection this way, using that you will get your other parameters.
A computer program would able to do this easily.
Sorry if I am wrong
Here is my question. Are you trying to shoot down projectiles that are aimed straight at you or are you trying to shoot down projectiles that are aimed at your headquarters located away from you on a hillside? And no, let's not get too attached to 80 m/s. Lets's call our projectile speed ##v_0## and the speed of the enemy projectile ##u_0##. Develop the equations and then you can tweak the values as you wish. I think that if you wish to be a successful game designer, you have to think abstractly in terms of parameters.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
