Projectile lands on an incline.
In summary: Dh, traveled. Next, you use the equation for the height, hf, to calculate the time, t, at which the height was reached. Finally, you use the time to calculate the height, hf, at the given distance.
moria
My problem looks like this:
http://i.imgur.com/3M9wE43.png
I need to find the point of impact and the time the body traveled.
I tried to find the time for 25 meters and with that the vertical velocity and height.
Ended up getting: t at 25m = 1.96 s , h=16.83 m vi=-1.03 m/s
I tried this: hf=vx*sin37*t = 7.67 m/s*t , it should mean that for every seconds the slope rises 7.66m in height.
After that I set up: hf = h + vi*t - 1/2*g*t^2 and got:
7.67*t = 16.83 - 1.03*t - 4.905*t^2
-4.905*t^2 - 8.7*t + 16.83 = 0
4.905*t^2 + 8.7*t - 16.83 = 0
The positive t was 1.17 s
Total time = 1.96 s + 1.17 s = 3.13 s
Height:
h = vi*t - 1/2*g*t^2
h = 18.20 m/s * 3.13 s - 1/2 * 9.81 m/s^2 * (3.13s)^2
h = 8.91 m
distance = vx*t
distance = 12.75 m/s * 3.13 s = 39.9 m
My problem is that the height and distance doesn't match, the tangent of the angle is: height/distance = 8.91/39.9-25=8.91/14.9=0.5979 , with arctg I get around 31 degrees, shouldn't I get 37 degrees here? This is what bothers me. Is the method I used correct? If not, what is the method I should use to solve it?
Height:
h = 8.91 m
Why use 3.13 sec. for the time to find the height?
distance = vx*t
Shouldn't the path of of the trajectory be the same as when I'm solving it without slope?
Wouldn't solving the height throught tg(37)*14.9 change the path?
Clear me up if I'm wrong, cause that is the part that bothers me the most about this problem.
Wouldn't solving the height thought tg(37)*14.9 change the path?
Yes, of course you're right about that.
You could use the equation for hf from the ramp, along with t = 1.17 s.
But looking at you're initial work, how did you get vx and vy ?
Try the following. Assume the projectile lands on the ramp a distance d horizontally from the base(where the ramp starts) and a distance h higher than the base. d and h are related by the angle 37 degrees. Now do the standard projectile equations d(vertically) = v(0)t = (1/2)at^2 and d(horizontally) = vt. If I say much more I would work the problem.
You could use the equation for hf from the ramp, along with t = 1.17 s.But looking at you're initial work, how did you get vx and vy ?
Vy=sin(55)*v and Vx=cos(55)*v v is 22.22 m/s
What to do with the 25 meters? I know how to solve it when the projectile is fried from the bottom of the ramp.
tg(alpha)=Sy/Sx
tg(alpha)=(vy*t-gt²/2)/(vx*t) and so on, but where do the 25m fit into all that?
moria,
It looks like you should use tan(37°), not sin(37°) for the ramp, hf.
Otherwise, your method appears to give a good result.
From the initial velocity of the projectile, you calculate the vertical, Vv, and horizontal velocity,Vh, knowing the angle of course.
The horizontal equation would be 25 + d = Vh * t
Now write the vertical equation. Remember that d and h are related by the angle of 37 deg.
With the risk that I might write bullsh*t:
25+d=vx*t
d=vx*t-25
tg(37)=h/vx*t-25
h=tg(37)*(vx*t-25)
h=vy*t-4.05t²
tg(37)*(vx*t-25)=vy*t-4.905t²
Like this?
d=vx*t-25 correct
h=vy*t-4.05t² correcttg(37)*(vx*t-25)=vy*t-4.905t² now solve for t and you are basically done. Yes, its a quadratic.
No
SammyS said:
moria,
You are right, when I do that I get 1.06 seconds and when I add it to 1.96 I get 3.02 seconds.
barryj said:
d=vx*t-25 correct
No
And doing this gets me the same result, 3.02 seconds.
Thanks for the help.
FAQ: Projectile lands on an incline.
What is a projectile landing on an incline?
A projectile landing on an incline refers to an object that is thrown or launched at an angle and lands on a sloped surface. This can include objects such as balls, bullets, or even rockets.
How does the incline affect the projectile's motion?
The incline can affect the projectile's motion by changing its direction and speed. The slope of the incline can also determine the height and distance the projectile will travel before landing.
What factors affect the trajectory of a projectile on an incline?
The factors that affect the trajectory of a projectile on an incline include the initial velocity, angle of launch, and the mass and shape of the object. The slope of the incline and air resistance can also impact the trajectory.
How can we calculate the trajectory of a projectile on an incline?
To calculate the trajectory of a projectile on an incline, we can use equations from projectile motion, such as the range equation or the maximum height equation. These equations take into account the initial velocity, angle of launch, and the acceleration due to gravity.
What are some real-world applications of a projectile landing on an incline?
Projectile motion on an incline has many real-world applications, such as in sports like throwing a football or shooting a basketball, or in engineering for designing bridges or calculating the trajectory of missiles. It is also an important concept in physics and can help us understand the motion of objects in the world around us.
