Projectile motion above ground given only angle and height
In summary: Here is the answer:The equation for the vertical position is:v = u + atThe equation for the horizontal position is:s = (u+v)/2twheres = displacement, u = initial velocity, v = final velocity, a = acceleration, t = time
raptor13
I'm having trouble with part A of this question
1. A ball is fired out at an angle of 30° from the platform of height h = 0.5 m as shown in Figure 1. It is subjected to the gravitational force only thus follows a projectile motion. It falls onto the ground after 0.6 seconds. Determine:
a). the ball's initial velocity V0 when it is fired out.
b). the distance the ball travels in the horizontal direction when it falls on the ground.
c). the magnitude and direction of the ball's velocity at t = 0.3 seconds after being fired out.
s=((u+v)/2)t
a=(v-u)/t
v=u+at
s=ut+0.5(at 2 )
v 2 = u2 + 2as
where s = displacement, u = initial velocity, v = final velocity, a = acceleration, t = time
i my first thought was at half the time the final vertical velocity would be zero but then i thought that would only be the case for projectiles that land at the same height as they were fired
Right. So what is your next attempt?
A final vertical velocity of zero would mean the ball travels horizontally. It doesn't do that at the height where it was fired, and it doesn't do that below that height either.
How long does the ball fly upwards? How long does the ball fly downwards?
s=((u+v)/2)t
a=(v-u)/t
v=u+at
s=ut+0.5(at 2 )
v 2 = u2 + 2as
Welcome to the PF. :smile:
You've listed some of the Relevant Equations, but I think you are missing a couple that will help.
List the equations for the position as a function of time in the vertical and horizontal directions, based on the initial position (x,y) and initial velocities, etc. Then solve the equations.
The horizontal motion will involve the horizontal velocity, which is not changing when there is no air resistance. The vertical motion is affected by the acceleration of gravity.
Can you list the equations for the vertical and horizontal positions as a function of time?EDIT --- Dang, I'm too slow!
Related to Projectile motion above ground given only angle and height
What is projectile motion?
Projectile motion is the motion of an object through the air or space under the influence of gravity.
What factors affect projectile motion?
The factors that affect projectile motion are initial velocity, angle of launch, air resistance, and height of launch.
How do you calculate the range of a projectile?
To calculate the range of a projectile, you can use the equation R = (V^2 * sin2θ) / g, where R is the range, V is the initial velocity, θ is the angle of launch, and g is the acceleration due to gravity.
Can you determine the maximum height of a projectile given only the angle and height of launch?
Yes, you can determine the maximum height of a projectile using the equation H = (V^2 * sin^2θ) / (2g), where H is the maximum height, V is the initial velocity, θ is the angle of launch, and g is the acceleration due to gravity.
How does air resistance affect the trajectory of a projectile?
Air resistance can decrease the range and height of a projectile as it travels through the air, causing it to follow a curved path rather than a straight line.
