Projectile motion and gravitational acceleration
In summary, a projectile is fired at an angle of 45 degrees from the horizontal and at its highest point, the radial and transverse components of its acceleration can be determined in terms of gravitational acceleration g. The question posed is a multiple choice one, asking for the correct expression for the radial and transverse acceleration values. After some discussion, it is determined that the correct answer is option D, which states that the radial acceleration is -g/(5)1/2 and the transverse acceleration is -2g/(5)1/2.
Idoubt
172
A projectile is fired from the origin O at an angle 45 degrees from the horizontal. At the
highest point P of its trajectory, determine the radial and transverse components of it's acceleration in terms of the gravitational acceleration g
x= vcos45 t
y= vsin45 t - 1\2gt2
No clue
how do you think will be the motion of projectile at max height?
parabolic, straight line, elliptical or something else?
I would say it is parabolic throughout the motion
what is direction of velocity at top most point?
Horizontal.
so now can you imagine that the instantaneous center of this velocity will be directly below it at some height.??
this center may or may not be on the ground
By centre you mean the centre of curvature right? yes I can see that, also if I know what that distance is, i can calculate the radial acceleration. But how do I find that the distance ( radius of curvature right? )
yes i mean center of curvature ... happy you know that
last time i had to explain it to someone ... it took me 15 mins
So now, radial acceleration is along radius ...
here ... radius is vertical(right?) ... so what is vertical acceleration?
well the vertical acceleration is g, but then wouldn't that imply that the instantaneous radial acceleration is g itself?
Yes that is correct!
well that seems great but the question was a multiple choice one and the choices were
1, ar = 2g/(5)1/2 ; atheta= g/(5)1\2
2, ar = -2g/(5)1/2 ; atheta= -g/(5)1\2
3, ar = g/(5)1/2 ; atheta= 2g/(5)1\2
4, ar = -g/(5)1/2 ; atheta= -2g/(5)1\2
This doesn't make any sense
is the question correct? and also is the question of good level so that we can be sure that question is wrong?
Well, it was asked in a national entrance ( I'm from India ) for pg, for Indian Institute of technologies, which is the best technical institute in the country, I think it's probably safe to say the question is legit
here is a screen shot if i missed something.
RL=http://img220.imageshack.us/i/jamq.jpg/][PLAIN]http://img220.imageshack.us/img220/1197/jamq.jpg
Uploaded with ImageShack.us
I'm also from india
is that an old question? if that is so there is a small chance that the question is wrong
can you tell me the year so that i can look it up in a book
jam ph 2007 question 10 . I downloaded the previous paper from their official site.
I figured it out now.
The prob was our origin. g is the radial acceleration only when the origin is the centre of curvature.
http://img691.imageshack.us/img691/1197/jamq.jpg
here ar= gsin alpha
and atheta= gcos alpha
the time for the whole flight T = (2)1/2V/g ( by putting y = 0 in the quad eq )
and the time to reach max height will have to be half this since x is linear in time . so T1/2 is v/(2)1/2g
solving for y and x we get, y = v2/4g and x = v2/2g
alpha = tan-1 (y/x) = tan-1(1/2) = 26.565
then turns out, ar = g/(5)1/2 ; atheta = 2g/(5)1/2
but this is magnitude, I think both acc has to be negative since ar is in the dir of decreasing r and atheta is in the direction of decreasing theta, so the right answer should be D, am I right?
FAQ: Projectile motion and gravitational acceleration
What is projectile motion?
Projectile motion is the motion of an object through the air or space under the influence of gravity. It is characterized by a constant horizontal velocity and a vertical acceleration due to gravity.
What is gravitational acceleration?
Gravitational acceleration is the acceleration due to the force of gravity. On Earth, it is approximately 9.8 meters per second squared (m/s²) and is represented by the symbol "g".
How does the angle of launch affect projectile motion?
The angle of launch determines the initial velocity and direction of the projectile. The greater the angle, the higher the initial velocity in the vertical direction, resulting in a longer flight time and a higher peak height. A smaller angle will result in a shorter flight time and a lower peak height.
What factors affect the range of a projectile?
The range of a projectile is affected by the initial velocity, the angle of launch, and the acceleration due to gravity. Other factors that may affect the range include air resistance, wind, and the shape of the object.
Can projectile motion be applied to objects on Earth and in space?
Yes, projectile motion can be applied to objects on Earth and in space as long as they are under the influence of gravity. However, other factors such as air resistance and gravitational pull from other objects may need to be taken into account in more complex scenarios.
