Projectile Motion Baseball Problem
The discussion revolves around calculating the minimum speed of a baseball hit by Babe Ruth over a 12m-high fence located 95m from home plate, with the ball being struck at a 40-degree angle. Participants suggest breaking down the initial velocity into horizontal (Vx) and vertical (Vy) components to find the time taken to reach the fence. The time is calculated using the horizontal distance and Vx, and then substituted into the vertical displacement formula to solve for the initial velocity (V). One participant attempts calculations but questions their accuracy, indicating a need for clarification on the approach. The conversation emphasizes using kinematic equations to derive the solution effectively.
pyromaniac2
Hey, have stared at this problem for a good half hour now, and my brain must be completely shot by now so I am having difficulty solving. If anyone can point me in the right direction, I would greatly appreciate it. Thanks!
When Babe Ruth hit a homer over the 12m-high right field fence 95m from home plate, roughly what was the minimum speed of the ball when it left the bat? Assume the ball was hit 1.0m above ground and its path initially made a 40 degree angle with the ground.
Let V be the initial velocity of the ball.
You know the angle it was hit at so you can resolve this velocity into horizontal and vertical components.
Since you now know the horizontal velocity, then what is the time taken, in terms of V, to travel the 95m to the fence ?
It will take the same amount of time for the ball to travel vertically from a height of 1 m up to a maximum height then descend until it is at a height of 12m above the ground.
Do you understand what I'm saying in the last sentence ?
This should allow you to solve your problem.
Attempt #1
Well, I think so. Although let me show you kind of what I tried to do with this and see how far off it is. I broke it into Vx and Vy with Vx= 95cos40 and Vy= 11sin40. I then took the 95 meters and divided it by the Vx (roughly 72.77) to get a time of (roughly) 1.305 seconds. I then put it all into the formula:
Change in position = V(t) + 1/2a(t)^2
To get a result somewhere along the lines of 78.16m/s
But that's just kind of a stab in the dark based on what I thought you were advising. Close or am I not even in the ballpark? (no pun intended)
In the outfield, I would say!
Vx = V.cos40
Vy = V.sin40
Vx = 95/t
where t is the time to travel 95 m horizontally.
You should now have t in terms of V.
It looks like you were doing the vertical displacement bit right with the correct formula. You should substitute for t into that formula and then solve for V.
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
TL;DR Summary: Find Electric field due to charges between 2 parallel infinite planes using Gauss law at any point Here's the diagram. We have a uniform p (rho) density of charges between 2 infinite planes in the cartesian coordinates system. I used a cube of thickness a that spans from z=-a/2 to z=a/2 as a Gaussian surface, each side of the cube has area A. I know that the field depends only on z since there is translational invariance in x and y directions because the planes are...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
