Projectile Motion Diver Jump Question
In summary, by using the kinematic equations and pythagoras theorem, the initial velocity of the diver was determined to be 11.25 m/s with a direction of 96° with respect to the horizontal surface of the water. However, the answer was incorrect and the angle should actually be 83.7°, indicating a mistake in the calculations.
lvn
A diver springs upward from a board that is 3.60 m above the water. At the instant she contacts the water her speed is 13.1 m/s and her body makes an angle of 67.3 ° with respect to the horizontal surface of the water. Determine her initial velocity, both (a) magnitude and (b) direction.
Basically what I've tried is I found initial velocity component X by finding the final velocity X component:
Vx = Vox
Vx = 13.1cos67.3
Vox = 5.06m/sThen I found the initial velocity Y component through the kinematic equation:
Vy^2 = Voy^2 - 2a(y-yo)
Voy = sqrt(171.61 - 2(-9.8)(-3.6))
Voy = sqrt(171.61 - -19.6(-3.6))
Voy = sqrt(171.61 - 70.56)
Voy = sqrt(101.05)
Voy = 10.05m/s
Using pythagoras to find Vo:
Vo = sqrt(10.05^2 + 5.06^2)
Vo = sqrt(101.0025 + 25.6036)
Vo = 11.25m/s
Theta:
Tan^-1 (Voy/Vox)
= 96
Answer was wrong - what am I doing wrong?
Figured it out.
FAQ: Projectile Motion Diver Jump Question
1. What is projectile motion?
Projectile motion is the motion of an object through the air, under the influence of gravity. It is a combination of horizontal and vertical motion, and can be described using principles of kinematics and Newton's laws of motion.
2. What is the "diver jump" in projectile motion?
The "diver jump" in projectile motion refers to the motion of a person jumping off a diving board into a pool. It is an example of projectile motion because the person's motion is affected by gravity as they move through the air and into the water.
3. How is the trajectory of a diver's jump calculated?
The trajectory of a diver's jump can be calculated using the equations of motion for projectile motion. These equations take into account the initial velocity, angle of launch, and acceleration due to gravity to determine the path of the object.
4. What factors affect projectile motion in a diver's jump?
The factors that affect projectile motion in a diver's jump include the initial velocity of the diver, the angle at which they jump, and the acceleration due to gravity. Other factors such as air resistance and wind can also have an impact on the trajectory of the jump.
5. How can projectile motion be applied in real life situations?
Projectile motion has many real life applications, such as in sports like diving, basketball, and football. It is also used in engineering and physics to design and analyze the motion of objects, such as in the development of airplanes and rockets.
