Projectile Motion: Dropping a Package
In summary, the conversation discusses finding the time it takes for a package to land when dropped from an airplane moving at a horizontal speed Vo, as well as the altitude of the plane and the velocity and speed of the package upon landing. The equations for acceleration and velocity are derived without the use of memorized equations, and the final answers are given in terms of Vo, L, and g. The correct method for finding the time is to consider only the horizontal motion, using the equation x = Vo(t) + xo, where xo is 0 and x = L. This results in the correct answer of t = L/Vo. Further discussion and clarification is given for notations and equations used in the conversation.
Metamorphose
Hi all! I just wanted to confirm whether or not the working I did for this question is wrong or right.
Here is the question:
An airplane is dropping an ad package in a remote area. The plane is moving horizontally at speed Vo and the package lands a horizontal distance L from where it was released by the plane.
Our prof. doesn't let us use memorized equations, we have to derive everything from the equation for acceleration.
[a.] Find the time it takes for the package to land.
Vx = ∫ax ∴ Vx = ax(t) + Vo.
x = ∫Vx ∴ x = 0.5ax(t)^2 + Vo(t) + xo.
The initial distance (x0) is 0 and the final distance (x) = L,
∴ L = 0.5ax(t)^2 + Vo(t)
Manipulating the equation for Vx gives ax = (Vx - Vox)/t.
Plugging this in gives L = 0.5(Vx - Vo)/t (t)^2 + Vo(t)
2L = t(Vx - Vo + 2Vo) ---> t = 2L/(Vx + Vo).
Since we can only give our answer in terms of Vo, L and g,
The final answer is t = 2L/(Vo) because the final velocity will be 0 m/s, at which point the package will have landed.
[b.] Find the altitude of the plane.
Vy = ∫ay ---> ay(t) + Voy
Y = ∫Vy ---> 0.5ay(t)^2 + Voy(t) + y0
ay = -g and y = 0,
∴ -0.5g(t)^2 + voy(2L/vox) + y0 = 0
Solving for y0 gives y0 = gL/v0
[c.] Find the velocity (vector) of the package when it lands.
So we're just going to find the velocity in the y direction as well as the x direction
Vy = ay(t) + voy.
voy = 0, and ay = -g,
therefore Vy = [-g(2L/Vox)]j
As for Vx,
Vx = [Vo]i
∴V = [Vo]i - [g(2L/Vox)]j
[d.] Find the speed of the package when it lands.
If I remember correctly, speed is just the magnitude of velocity, which would be V = (Vx^2 + Vy^2)^0.5
∴ V = [(Vo)^2 + (-g(2L/Vox))^2]^0.5
V = [Vo^2 + (4g^2(L^2))/V0x^2))^0.5
I would greatly appreciate it if someone could read over this and tell me where I made mistakes. I know that ax in the x direction is always 0, which should alter part a into L/Vox instead of 2L/Vox.
Sorry, but this completely wrong. Looks to me like you're not thinking about what the equations mean.
Vo is horizontal, whereas the acceleration is vertical. So it makes no sense to write x = 0.5ax(t)^2 + Vo(t) + xo.
It would also be wrong to take the final velocity as 0 because it has landed! The impact itself is not allowed for in the equation, so you have to take the final velocity as what it was just before impact.
If we ignore air resistance, the vertical and horizontal motions are quite independent. If you just think about the horizontal motion you will be able to answer [a] easily. Indeed, you seem to have done that correctly in the footnote.
Having found t, thinking only about vertical motion will allow you to solve and the vertical component of [c]. Finally, bring in the horizontal component of speed on landing to answer [c] completely.
Thank you for taking the time to look over this. We are only allowed to answer in terms of vo, g and L
I was actually looking over it again, and I noticed that when you are initially integrating Vx, which gives ax(t) + Vo, because ax IS essentially 0, Vx simply becomes equal to Vo. Integrating this to give x gives Vo(t) + xo. Based on the conditions given above, xo is 0 and x = L. Solving for time:
x = Vo(t) + xo
L = Vo(t)
t = L/Vo.
Does this seem to be correct?
I'm just looking at your last post and answering this on my phone, so I'll be brief. Integrating a velocity does not give and acceleration, but a displacement. The derivative of velocity is acceleration.
Metamorphose said:
x = Vo(t) + xo
L = Vo(t)
t = L/Vo.
Yes, that's exactly it. No need to think about the vertical direction if you can answer it by just considering the horizontal direction alone. You can then use that time to answer part (b).
x = Vo(t) + xo
L = Vo(t)
t = L/Vo.
That appears to be following what I suggested and indeed gets the right answer.
I do have some problems with your description and notation.
You don't mean "integrating Vx", but rather "integrating ax to obtain Vx".
The notation Vo(t) suggests Vo as a function of t. You mean simply Vo multiplied by t, which should be written Vo.t or (in software style) Vo*t.
Can you now get and [c]?
Related to Projectile Motion: Dropping a Package
1. What is projectile motion?
Projectile motion is the motion of an object through the air, under the influence of gravity. It is characterized by a curved path due to the combination of a horizontal velocity and a vertical acceleration.
2. How is projectile motion different from regular motion?
Projectile motion is different from regular motion because it involves both horizontal and vertical components, while regular motion only has one direction of motion. In projectile motion, the object is constantly changing direction due to the influence of gravity.
3. How does dropping a package demonstrate projectile motion?
Dropping a package demonstrates projectile motion because the package is initially at rest and then begins to move under the influence of gravity. As it falls, it follows a curved path due to the combination of its horizontal and vertical velocities.
4. What factors affect the trajectory of a dropped package?
The trajectory of a dropped package is affected by the initial height at which it is dropped, the initial horizontal velocity, and the force of gravity. Air resistance can also play a role in altering the trajectory.
5. How can we calculate the trajectory of a dropped package?
The trajectory of a dropped package can be calculated using the equations of motion, which take into account the initial height, horizontal velocity, and acceleration due to gravity. Other factors, such as air resistance, may also need to be considered in more complex calculations.
