Projectile Motion: Find Launch Speed
In summary, the conversation discusses the use of a slingshot by an alpine rescue team to send an emergency medical packet to stranded climbers. The team needs to calculate the initial velocity of the slingshot in order to reach the climbers on a ledge 270m high and 390m away. The conversation goes on to explain the use of various equations to solve for the initial velocity, with the result being 77.45 m/s. However, further discussion suggests a slightly larger velocity may be needed to hit the ledge accurately.
Calam1tous
Your alpine rescue team is using a slingshot to send an emergency medical packet to climbers stranded on a ledge on the side of a mountain. If the height of the ledge is 270m (y = 270m) and the ledge is 390m from the slingshot (x = 390m), what is the initial velocity of the slingshot if the launch angle is 70 degrees?
V(o) = ?
x = 390m
y = 270m
Theta = 70 degrees
a(y) = -9.81
a(x) = 0
Since the only acceleration is constant, I know that I must solve this problem using these equations:
V = V(0) + at
X = X(0) + V(0)t + 1/2at^2
V^2 = V(0)^2 + 2ax
When I first attempted the problem, I figured I would have to solve for variables using the y-axis.
I used a variation of the third equation:
V(y)^2 = V(0)(y) + 2ay
And solved for V(0)(y). (V(y) is 0 when it hits the ledge):
0 = V(0)(y) + 2(9.81)(270)
I got:
72.78 = V(0)(y)
and then I plugged it into:
sin(70) = V(0)(y) / V(0)
V(0) = V(0)(y) / sin(70)
V(0) = 77.45 m/s
This was the only valid approach I could think of, but the online HW program I'm using says that this is the incorrect answer. I'm sure that this is very simple and I am just ignorant of something, but can anyone provide any pointers to help me out?
Thanks!
I didn't see that given in the question. It would be interesting to use the basic distance equations to see if your velocity causes the package to hit the ledge. Spreadsheet?
The two equations define the trajectory. You just need to put in the (390,270) to make the hit. Write the horizontal distance equation 390 = Vi*cos(70)*t
and the vertical distance equation 270 = Viy*t + ½*a*t².
That gives you two unknowns (t and Vi) and two equations.
They solve to Vi somewhat larger than you got.
FAQ: Projectile Motion: Find Launch Speed
1. What is projectile motion?
Projectile motion is the motion of an object that is launched into the air and moves under the influence of gravity alone. Examples of projectiles include a baseball being thrown, a bullet fired from a gun, or a rocket launched into space.
2. How is launch speed calculated in projectile motion?
The launch speed in projectile motion can be calculated using the equation: v = √(g * d / sin(2θ)), where g is the acceleration due to gravity, d is the horizontal distance traveled by the object, and θ is the angle of launch.
3. What factors affect the launch speed in projectile motion?
The launch speed in projectile motion is affected by the angle of launch, the acceleration due to gravity, and any external forces acting on the object, such as air resistance. The mass and shape of the object can also affect the launch speed.
4. How does the launch angle affect the launch speed in projectile motion?
The launch angle has a significant impact on the launch speed in projectile motion. The optimal angle for maximum launch speed is 45 degrees, as it allows for the greatest horizontal distance traveled while also minimizing the effect of air resistance.
5. Can the launch speed in projectile motion be greater than the initial launch velocity?
Yes, the launch speed in projectile motion can be greater than the initial launch velocity if the object experiences a boost or acceleration during its flight. For example, a rocket launched into space will continue to gain speed after it is launched due to the force of its engines.
