Projectile motion flight time of ball
To find the flight time of a ball thrown at an angle, the equation t = (2 v0 sin theta)/g is used. The initial velocity v0 is derived from the relationship involving the height H and gravitational acceleration g, leading to the equation (v0 sin theta)^2 = 2gH. The challenge arises when trying to eliminate the variable R from the calculations, as the problem specifies that only H and g should remain. By substituting the expression for (v0 sin theta) into the flight time equation, the solution can be simplified. Ultimately, the focus is on expressing flight time solely in terms of H and g.
ronny45
[SOLVED] Projectile motion
A ball is thrown with an intial velocity of v0 at an angle theta from the horizontal. Find the flight time of the ball in terms of H and g only.
Ok. I found theta to be the tan inverse of 4R/H. Thus, the initial velocity is sqrt[Rg/sin(2tan-1(4R/H))] - a little longwinded but accurate. However, my problem arises when I plug these values into the above equation and those really nasty 'R's refuse to go away, and the problem specifically states that g and H should be my only variables. I feel like i must be missing something really obvious, and if so, i apologise in advance, but please help anyway! Thank you!
When the ball reaches the height H, its velocity is equal to zero. So using kinametics equation we get (vosin theta)^2 = 2gH. From this equation find the value of (v0sin theta) and plug it the relevant equation.
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up will act downwards and maximum static friction will act downwards Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
