Projectile Motion- Incline vs. Horizontal Surface
In summary, two identical metal blocks, H and A, are released at the same time from equal heights on frictionless ramps. Block H leaves the table from a horizontal surface, while block A leaves from a 30 degree incline. Both blocks leave the table from the same height. It is not possible to determine which block, if either, will be traveling faster when it reaches its highest point after leaving the table, without using equations. In order to determine which block will travel a greater horizontal distance before hitting the floor, additional information is needed about their horizontal velocities and the time it takes for each to hit the floor. Similarly, to determine which block will have a greater speed at the instant it hits the floor, additional information is needed
phzzo
Two identical metal blocks, H and A, are placed at equal heights on frictionless ramps as shown above. The blocks are released at the same time, travel down the ramp, and then slide off their respective ends of the table. Block H leaves the table from a horizontal surface. Block A leaves the table at a 30 degree incline. Both blocks leave the table from the same height.
1) Indicate which block, if either, will be traveling faster when it reaches its highest point after leaving the table. Justify your answer qualitatively without using any equations.
2) Justify your answer about which block, if either, will be traveling faster when it reaches its highest point quantitatively using appropriate equations.
3) Is enough information provided to determine which block, if either, travels a greater horizontal distance before hitting the floor? If so, indicate your prediction and justify your answer qualitatively. If not, indicate what additional information is needed and explain how you would use that information to determine which block would travel a greater horizontal distance.
4) Is enough information provided to determine which block, if either, has a greater speed at the instant it hits the floor? If so, indicate your prediction and justify your answer qualitatively. If not, indicate what additional information is needed and explain how you would use that information to determine which block would hit the ground with a greater speed.
x = vxt + x0
y = 1/2ayt + v0yt + y0
1) Vertical velocity is 0 at highest point, so speed depends on horizontal velocity? I feel like neither block may be traveling faster, but I don't know why.
2) VAcos30 = VAx I think, I'm not sure about VHx.
3) There is not enough information. To find the horizontal distance of each, I would need to know their horizontal velocities and the time it takes for each to hit the floor to plug into x = vxt + x0
4) There is not enough information. To find their final velocities, I think I would need their horizontal velocities and the time, as well as their initial vertical velocities, which would be 0 and VAsin30? Vy = ayt + V0y finds their vertical velocities, and their final speeds can be found with the Pythagorean theorem?
When the blocks just reach the end of the wedge, they will have equal kinetic energies, since both have lost the same amount of potential energies. will the velocities of the block become different at the instant they leave contact?
Likes phzzo
Oh, no they won't! Thank you!
so they leave contact withe equal velocities.
the only difference is the angle of projection.
also, the block A loses some kinetic energy as it goes up so the magnitude of velocity has decreased since it has lost the vertical component. So which block has more velocity at highest point?
Do the quantitative part yourself. I will give you some ideas
So VH = VHx = VA, and VAcos30 = VHcos30 = VAx, and the velocity of H will be greater?
yes.
how are the horizontal velocities the same if block a has a longer distance to accelerate?
The Horizontal velocities aren't the same. ##v_{A_X} = v_{H_X} \cos 30##. The magnitude of their overall velocities should be the same at the point of leaving the table though, as they have both traveled through the same altitude drop - you can see this by approaching it from an Energy perspective. It's just that one block has its velocity only in the x-direction, and the other has components in x and y.
yes but, how can you prove it without an energy perspective.
Well, the energy argument is so much simpler, that I hadn't really considered how to prove it without using that particular tool.
I suppose if we're discounting friction and air resistance, it is trivial to prove that the blocks are traveling at the same speed as they reach the dotted line, as they have been accelerated for the same period of time. After that, block H will continue at the same speed until it leaves the table, so we just have to prove that block A is traveling at the same speed when it leaves the table as it is when it enters the curved dip. I guess you could express the kinematic equations in terms of ##\ddot \theta## and it should turn out that the speed is unchanged at the point of leaving the table, while the direction of the velocity is altered...but it's just a thought.
Well, no, they leave with equal speeds. If the directions are different than necessarily the velocities differ.
Related to Projectile Motion- Incline vs. Horizontal Surface
1. What is projectile motion?
Projectile motion is the motion of an object that is projected or thrown into the air and moves along a curved path under the influence of gravity.
2. What is the difference between incline and horizontal surface in projectile motion?
Incline and horizontal surfaces affect the trajectory of a projectile differently. On an incline, the projectile's motion is influenced by both gravity and the incline's slope, resulting in a curved path. On a horizontal surface, the projectile's motion is only influenced by gravity, resulting in a straight path.
3. How does the angle of the incline affect projectile motion?
The angle of the incline affects the trajectory of the projectile. A steeper incline will result in a shorter and higher curved path, while a shallower incline will result in a longer and lower curved path.
4. What is the relationship between the initial velocity and the range of a projectile on an incline?
The initial velocity of a projectile on an incline affects the range it will travel. A higher initial velocity will result in a longer range, while a lower initial velocity will result in a shorter range.
5. How does the mass of the projectile affect its motion on an incline?
The mass of the projectile does not affect its motion on an incline, as long as air resistance and other external factors are negligible. The projectile's trajectory is determined by the initial velocity and the angle of the incline.
