Projectile motion involving mass
In summary, the conversation discussed the equation for finding the distance an object travels when shot horizontally at a given velocity (v) and the ability to calculate changes in velocity. It was also mentioned that the mechanism by which the mass changes can affect the distance traveled. It was clarified that when comparing two objects with the same initial velocity, the heavier one will typically travel farther due to aerodynamics. However, if the drag equation is included, there is no simple answer as two objects with the same mass but different shapes will behave differently.
Glype11
If the only variable that is changed is mass. What equation would I use to find the distance an object travels that is shot horizontally at a velocity (v) and I would like to be able to calculate the change in velocity?
What is the mechanism by which the mass changes? It makes a big difference exactly how this happens.
If "an object travels that is shot horizontally at a velocity (v)", any object shot at velocity (v) will travel the same horizontal distance (neglecting air resistance). The horizontal component of travel experiences no acceleration so the initial velocity (v) remains constant.
The vertical component is experiencing a downward acceleration due to gravity. This acceleration is the same for any mass object so they reach the ground together. Like dropping a basketball and a medicine ball at the same time - they reach the ground together.
If the mechanism that shoots the first object remains the same, then shoots a larger mass object, this second object will not have "velocity (v)" to begin with. Is this what you mean?
The case I had in mind, was comparing two projectiles fired at the same velocity, the heavier one will travel farther.
I know it comes down to aerodynamics. I wanted to see if there was a more simplified way of solving these types of problems rather starting with the drag equation.
If you want to include the drag than there is no simple answer. Two objects with the same mass but different shapes will behave differently.
FAQ: Projectile motion involving mass
What is projectile motion involving mass?
Projectile motion involving mass is the study of the motion of an object that is launched into the air and experiences the force of gravity. It takes into account the mass of the object and how it affects the trajectory of its motion.
How is the mass of the object related to its projectile motion?
The mass of the object affects its projectile motion because it determines the object's inertia, which is the resistance to changes in motion. Objects with larger masses have greater inertia and therefore will have different trajectories compared to objects with smaller masses when launched with the same initial velocity.
What is the role of gravity in projectile motion involving mass?
Gravity plays a critical role in projectile motion involving mass. It is the force that pulls the object towards the ground, causing it to accelerate. This acceleration due to gravity remains constant throughout the motion and affects the trajectory of the object.
Can the angle of launch affect the projectile motion of an object with mass?
Yes, the angle of launch can significantly impact the projectile motion of an object with mass. The angle of launch determines the initial velocity and direction of the object, which affects its trajectory. Depending on the angle, the object may have a longer or shorter flight time and a higher or lower peak height.
How can we calculate the velocity and displacement of an object in projectile motion involving mass?
To calculate the velocity and displacement of an object in projectile motion involving mass, we can use the equations of motion. These equations take into account the initial velocity, acceleration due to gravity, and time. Alternatively, we can use vector components to break down the velocity into horizontal and vertical components and calculate them separately.
