Projectile Motion man tosses object
In summary, a man tosses an object with an initial velocity of 20 m/s into a room, and is 2.0 m above the ground. The room is 10.0 m above the ground. The object falls an angle of 8.0 degrees (in radians) from the man to the ground.
Acnhduy
31
A man tosses object with initial velocity of 20 m/s into a room, and is 2.0 m above the ground. The room is 10.0 m above the ground.
In a provided diagram, the distance from man to room horizontally is 31.8 m.
I am required to solve for the angle of the object as it leaves the mans hand.
Big 5
vix= 20cosθ
viy= 20sinθ
To solve for θ, I must use the initial velocity given, broken up into components.
Since I am given the vertical displacement (8.0 m) and horizontal displacement (31.8 m) , I can use 2 formulas and substitute one into the other, by isolating t as it is common to both.
dx= vixt
31.8 = 20cosθt
t= 31.8 / 20cosθ
dy= viyt + 0.5ayt2
8.0 = 20sinθt - 4.9t2
8.0 = 20sinθ(31.8 / 20cosθ) - 4.9(31.8 / 20cosθ)2
8.0 = (31.8sinθ / cosθ) - 4.9(2.5281 / cos2θ)
8.0 = (31.8sinθ / cosθ) - (12.39 / cos2θ)
and now I'm stuck... I tried moving to one side and changing to common denominator...
0 = (31.8sinθ / cosθ) - (12.39 / cos2θ) - 8.0
0 = (31.8sinθcosθ - 12.39 - 8.0cos2θ) / cos2θ
0 = 31.8sinθcosθ - 12.39 - 8.0cos2θ
0 = 15.9sin2θ - 12.39 - 8.0(1 - sin2θ)
0 = 15.9sin2θ - 12.39 - 8.0 + 8sin2θ
0 = 8sin2θ + 15.9sin2θ - 20.39
but no luck...
i thought it looked like a quadratic at first, but I don't think it works with sin2θ
any suggestions? thank you :)
... so you have interpreted the question as asking about the direction of the initial velocity vector, given the ball passes through points A and B (going from A to B) and you know the speed at A.
... trig identities not helping you - you may be able to do it geometrically seeing ##2\sin^2\theta = 1-\cos2\theta## ... or is there another kinematic equation you haven't considered yet - that may be called into play?
i.e. have you used all the information at your disposal yet?
Notes:
do not put the numbers in until the end or you'll get turned around.
keep track of your reasoning all the way through.
Hmmm ... perhaps:
... go back to where it looks like you almost have a quadratic in ##\cos\theta##,
... multiply through by ##\sec^2\theta## ... from there, Pythagoras should get you a quadratic in ##\tan\theta##.
Likes 1 person
Mhm. Didnt even notice that it could be changed to secant. Thankyou
No worries.
The tan vs sec identities crop up a lot - especially in exams.
FAQ: Projectile Motion man tosses object
What is Projectile Motion?
Projectile motion is the motion of an object through the air that is subject only to the acceleration of gravity. This type of motion is characterized by both horizontal and vertical components, resulting in a curved path.
What factors affect projectile motion?
The factors that affect projectile motion include the initial velocity, angle of launch, and the acceleration due to gravity. Air resistance can also impact the trajectory of a projectile.
How does the angle of launch affect projectile motion?
The angle of launch is an important factor in determining the distance and height of a projectile. The optimal angle for maximum distance is 45 degrees, while the optimal angle for maximum height is 90 degrees.
What is the formula for calculating the range of a projectile?
The formula for calculating the range of a projectile is R = (v^2 * sin(2θ)) / g, where R is the range, v is the initial velocity, θ is the angle of launch, and g is the acceleration due to gravity.
How does air resistance affect projectile motion?
Air resistance can slow down a projectile and cause it to deviate from its expected path. The effect of air resistance is greater on objects with larger surface areas and lower mass.
